Home
Structural and Bar Sections
Flat Sections
Flat bar structural sections
Designation | Width | Depth | Weight | |
in | in | lbs/ft | ||
insert! | 3/8 x 1 1/4 | 1.25 | 0.375 | 1.594 |
insert! | 3/8 x 1 3/8 | 1.375 | 0.375 | 1.753 |
insert! | 3/8 x 1 1/2 | 1.5 | 0.375 | 1.913 |
insert! | 3/8 x 1 3/4 | 1.75 | 0.375 | 2.231 |
insert! | 3/8 x 2 | 2 | 0.375 | 2.550 |
insert! | 3/8 x 2 1/4 | 2.125 | 0.375 | 2.869 |
insert! | 3/8 x 2 1/2 | 2.5 | 0.375 | 3.188 |
insert! | 3/8 x 3 | 3 | 0.375 | 3.825 |
insert! | 3/8 x 3 1/2 | 3.5 | 0.375 | 4.463 |
insert! | 3/8 x 4 | 4 | 0.375 | 5.100 |
insert! | 3/8 x 4 1/2 | 4.5 | 0.375 | 5.738 |
insert! | 3/8 x 5 | 5 | 0.375 | 6.375 |
insert! | 3/8 x 6 | 6 | 0.375 | 7.650 |
insert! | 1/2 x 5/8 | 0.625 | 0.5 | 1.063 |
insert! | 1/2 x 3/4 | 0.75 | 0.5 | 1.275 |
insert! | 1/2 x 7/8 | 0.875 | 0.5 | 1.488 |
insert! | 1/2 x 1 | 1 | 0.5 | 1.700 |
insert! | 1/2 x 1 1/8 | 1.125 | 0.5 | 1.913 |
insert! | 1/2 x 1 1/4 | 1.25 | 0.5 | 2.125 |
insert! | 1/2 x 1 3/4 | 1.75 | 0.5 | 2.550 |
insert! | 1/2 x 2 | 2 | 0.5 | 2.975 |
insert! | 1/2 x 2 1/4 | 2.25 | 0.5 | 3.400 |
insert! | 1/2 x 2 1/2 | 2.5 | 0.5 | 3.825 |
insert! | 1/2 x 3 | 3 | 0.5 | 4.250 |
insert! | 1/2 x 3 1/4 | 3.25 | 0.5 | 5.100 |
insert! | 1/2 x 3 1/2 | 3.5 | 0.5 | 5.525 |
insert! | 1/2 x 4 | 4 | 0.5 | 5.950 |
insert! | 1/2 x 4 1/2 | 4.5 | 0.5 | 6.800 |
insert! | 1/2 x 5 | 5 | 0.5 | 7.650 |
insert! | 1/2 x 6 | 6 | 0.5 | 8.500 |
insert! | 1/2 x 8 | 8 | 0.5 | 10.20 |
insert! | 5/8 x 3/4 | 0.75 | 0.625 | 1.594 |
insert! | 5/8 x 7/8 | 0.875 | 0.625 | 1.859 |
insert! | 5/8 x 1 | 1 | 0.625 | 2.125 |
insert! | 5/8 x 1 1/4 | 1.25 | 0.625 | 2.656 |
insert! | 5/8 x 1 1/2 | 1.5 | 0.625 | 3.188 |
insert! | 5/8 x 1 3/4 | 1.75 | 0.625 | 3.719 |
insert! | 5/8 x 2 | 2 | 0.625 | 4.250 |
insert! | 5/8 x 2 1/4 | 2.25 | 0.625 | 4.781 |
insert! | 5/8 x 2 1/2 | 2.5 | 0.625 | 5.313 |
insert! | 5/8 x 2 3/4 | 2.75 | 0.625 | 5.844 |
insert! | 5/8 x 3 | 3 | 0.625 | 6.375 |
insert! | 5/8 x 3 1/2 | 3.5 | 0.625 | 7.438 |
insert! | 5/8 x 3 3/4 | 3.75 | 0.625 | 7.969 |
insert! | 5/8 x 4 | 4 | 0.625 | 8.500 |
insert! | 5/8 x 5 | 5 | 0.625 | 10.63 |
insert! | 5/8 x 5 1/2 | 5.5 | 0.625 | 11.69 |
insert! | 5/8 x 6 | 6 | 0.625 | 12.75 |
insert! | 5/8 x 8 | 8 | 0.625 | 17.00 |
insert! | 3/4 x 7/8 | 0.875 | 0.75 | 2.231 |
insert! | 3/4 x 1 | 1 | 0.75 | 2.550 |
insert! | 3/4 x 1 1/8 | 1.125 | 0.75 | 2.869 |
insert! | 3/4 x 1 1/4 | 1.25 | 0.75 | 3.188 |
insert! | 3/4 x 1 1/2 | 1.5 | 0.75 | 3.825 |
insert! | 3/4 x 1 3/4 | 1.75 | 0.75 | 4.463 |
insert! | 3/4 x 2 | 2 | 0.75 | 5.100 |
insert! | 3/4 x 2 1/4 | 2.25 | 0.75 | 5.738 |
insert! | 3/4 x 2 1/2 | 2.5 | 0.75 | 6.375 |
insert! | 3/4 x 2 3/4 | 2.75 | 0.75 | 7.013 |
insert! | 3/4 x 3 | 3 | 0.75 | 7.650 |
insert! | 3/4 x 3 1/2 | 3.5 | 0.75 | 8.925 |
insert! | 3/4 x 4 | 4 | 0.75 | 10.20 |
insert! | 3/4 x 4 1/2 | 4.5 | 0.75 | 11.48 |
insert! | 3/4 x 5 | 5 | 0.75 | 12.75 |
insert! | 3/4 x 6 | 6 | 0.75 | 15.30 |
insert! | 3/4 x 6 1/2 | 6.5 | 0.75 | 16.58 |
insert! | 3/4 x 8 | 8 | 0.75 | 20.40 |
insert! | 7/8 x 1 | 1 | 0.875 | 2.975 |
insert! | 7/8 x 1 1/2 | 1.5 | 0.875 | 4.463 |
insert! | 7/8 x 2 | 2 | 0.875 | 5.950 |
insert! | 7/8 x 3 | 3 | 0.875 | 8.925 |
insert! | 7/8 x 4 | 4 | 0.875 | 11.90 |
insert! | 7/8 x 5 | 5 | 0.875 | 14.88 |
insert! | 7/8 x 6 | 6 | 0.875 | 17.85 |
insert! | 1 x 1 1/4 | 1.25 | 1 | 4.250 |
insert! | 1 x 1 3/8 | 1.375 | 1 | 4.675 |
insert! | 1 x 1 1/2 | 1.5 | 1 | 5.100 |
insert! | 1 x 1 3/4 | 1.75 | 1 | 5.950 |
insert! | 1 x 2 | 2 | 1 | 6.800 |
insert! | 1 x 2 1/4 | 2.25 | 1 | 7.650 |
insert! | 1 x 2 1/2 | 2.5 | 1 | 8.500 |
insert! | 1 x 3 | 3 | 1 | 10.20 |
insert! | 1 x 3 1/2 | 3.5 | 1 | 11.90 |
insert! | 1 x 4 | 4 | 1 | 13.60 |
insert! | 1 x 4 1/2 | 4.5 | 1 | 15.30 |
insert! | 1 x 5 | 5 | 1 | 17.00 |
insert! | 1 x 5 1/2 | 5.5 | 1 | 18.70 |
insert! | 1 x 6 | 6 | 1 | 20.40 |
insert! | 1 x 8 | 8 | 1 | 27.20 |
insert! | 1 x 10 | 10 | 1 | 34.00 |
insert! | 1 x 11 | 11 | 1 | 37.40 |
insert! | 1 x 12 | 12 | 1 | 40.80 |
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
and more.
4 30
