Inserting a surface based on UTM (Universal Transversal Mercator) coordinates.
Delete, modify or add North- and East-coordinates for the corners in area in the table below. "Insert!" to add the area to your model. Insertion point is row 0.
| zone | |
| - | latitude (0) |
| - | longitude (0) |
| country | |
| location | |
| Set this position to the models location! | |
| thickness | |
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 7
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
