Home
Piping
Pipes and Tubes
Dimensions and weights of thermoplastic pipe schedule 40 - Imperial Dimensions
ASTM D1785 "Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe, Schedules 40, 80, and 120" is manufactured to meet the needs of a broad range of industrial, commercial and residential piping systems.
ASTM D1785 covers pipes made for water distribution and irrigation systems.
ASTM F441 Standard Specification for Chlorinated Poly(Vinyl Chloride) (CPVC) Plastic Pipe, Schedules 40 and 80
Nominal Diameter in |
Outside Diameter in |
Inside Diameter in |
Wall Thickness in |
Weight lb/100 ft |
Inside Area in**2 |
| insert! | 1/8 | 0.405 | 0.261 | 0.072 | 3.27 | 0.05 |
| insert! | 1/4 | 0.540 | 0.354 | 0.093 | 5.6 | 0.10 |
| insert! | 3/8 | 0.675 | 0.483 | 0.096 | 7.57 | 0.18 |
| insert! | 1/2 | 0.840 | 0.608 | 0.116 | 11.4 | 0.29 |
| insert! | 3/4 | 1.050 | 0.810 | 0.120 | 15.2 | 0.52 |
| insert! | 1 | 1.315 | 1.033 | 0.141 | 22.5 | 0.84 |
| insert! | 1 1/4 | 1.660 | 1.364 | 0.148 | 30.5 | 1.46 |
| insert! | 1 1/2 | 1.900 | 1.592 | 0.154 | 36.6 | 1.99 |
| insert! | 2 | 2.375 | 2.049 | 0.163 | 49.1 | 3.30 |
| insert! | 2 1/2 | 2.875 | 2.445 | 0.215 | 77.9 | 4.69 |
| insert! | 3 | 3.500 | 3.042 | 0.229 | 102 | 7.26 |
| insert! | 3 1/2 | 4.000 | 3.520 | 0.240 | 123 | 9.73 |
| insert! | 4 | 4.500 | 3.998 | 0.251 | 145 | 12.5 |
| insert! | 5 | 5.563 | 5.017 | 0.273 | 197 | 19.8 |
| insert! | 6 | 6.625 | 6.031 | 0.297 | 256 | 28.6 |
| insert! | 8 | 8.625 | 7.943 | 0.341 | 385 | 49.5 |
| insert! | 10 | 10.750 | 10.673 | 0.039 | 546 | 89.4 |
| insert! | 12 | 12.750 | 11.890 | 0.430 | 722 | 111.0 |
| custom! |
Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
