Softwood Dimensional Lumber and Timber Sizes - Imperial Units
Nominal Dimension |
Width in |
Depth in |
| insert! | 1 x 2 | 0.75 | 1.5 |
| insert! | 1 x 3 | 0.75 | 2.5 |
| insert! | 1 x 4 | 0.75 | 3.5 |
| insert! | 1 x 6 | 0.75 | 5.5 |
| insert! | 1 x 8 | 0.75 | 7.25 |
| insert! | 1 x 10 | 0.75 | 9.25 |
| insert! | 1 x 12 | 0.75 | 11.625 |
| insert! | 2 x 2 | 1.5 | 1.5 |
| insert! | 2 x 3 | 1.5 | 2.5 |
| insert! | 2 x 4 | 1.5 | 3.5 |
| insert! | 2 x 6 | 1.5 | 5.5 |
| insert! | 2 x 8 | 1.5 | 7.25 |
| insert! | 2 x 10 | 1.5 | 9.25 |
| insert! | 2 x 12 | 1.5 | 11.25 |
| insert! | 2 x 14 | 1.5 | 13.25 |
| insert! | 4 x 4 | 3.5 | 3.5 |
| insert! | 4 x 6 | 5.5 | 3.5 |
| insert! | 6 x 6 | 5.5 | 5.5 |
| insert! | 8 x 8 | 7.25 | 7.25 |
| custom! |
The dimensional lumber 2 x 4 inches is 2 x 4 inches only when the board is first rough sawn from the log. In the drying and planing process the board is reduced to 1.5 x 3.5 inches
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
