Home
HVAC
Duct Work - Elbows
Rectangular duct elbows with square throat
Insert! |
Note! Flanges are not included and the components are made with closed ends. If you want open ends - right click the inserted component, select the end faces and erase.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
