Home  > Boards  >
OSB Boards
Square edged OSB boards - Metric Units
lumber
Nominal Dimension Length Width Thickness
mm mm mm
insert! 2397 x 1197 x 11 2397 1197 11
insert! 2397 x 1197 x 11 2397 1197 15
insert! 2397 x 1197 x 11 2397 1197 18
insert! 2440 x 1220 x 8 2440 1220 8
insert! 2440 x 1220 x 11 2440 1220 11
insert! 2440 x 1220 x 15 2440 1220 15
insert! 2440 x 1220 x 18 2440 1220 18
insert! 2440 x 1200 x 30 2440 1200 30
custom!
Length
Color
Offset
OSB - Oriented Strand Boards - are engineered wood-based panels consisting of strands of wood which are bonded together with a synthetic resin. The strands are pressed together in layers. In the outer layers strands are generally oriented longitudinally in line with the panel length, whereas in the middle layers strands generally lie in a cross wise direction.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
