Square edged OSB boards - Imperial Units
Nominal Dimension | Length | Width | Thickness | |
in | in | in | ||
insert! | 8 x 4 x 1/4 | 95.93 | 47.5 | 0.225 |
insert! | 8 x 4 x 7/16 | 95.93 | 47.5 | 0.418 |
insert! | 8 x 4 x 1/2 | 95.93 | 47.5 | 0.483 |
insert! | 8 x 4 x 19/32 | 95.93 | 47.5 | 0.578 |
insert! | 8 x 4 x 23/32 | 95.93 | 47.5 | 0.703 |
custom! |
OSB - Oriented Strand Boards - are engineered wood-based panels consisting of strands of wood which are bonded together with a synthetic resin. The strands are pressed together in layers. In the outer layers strands are generally oriented longitudinally in line with the panel length, whereas in the middle layers strands generally lie in a cross wise direction.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
