Home
HVAC
Duct Work Tees
Duct work tees 45 degrees - imperial units
Nominal Diameter | Run Diameter | Run | Run Thickness | Outlet Diameter | Outlet | Outlet Thickness | |
in | in | in | in | in | in | in | |
insert! | 3 | 3 | 3 | 0.0276 | 3 | 3 | 0.276 |
insert! | 4 | 4 | 4 | 0.0277 | 4 | 4 | 0.0276 |
insert! | 5 | 5 | 5 | 0.0276 | 5 | 5 | 0.0276 |
insert! | 6 | 6 | 6 | 0.0276 | 6 | 6 | 0.0276 |
insert! | 8 | 8 | 8 | 0.0276 | 8 | 8 | 0.0276 |
insert! | 10 | 10 | 10 | 0.0276 | 10 | 10 | 0.0276 |
insert! | 12 | 12 | 12 | 0.0276 | 12 | 12 | 0.0276 |
insert! | 14 | 14 | 14 | 0.0276 | 14 | 14 | 0.0276 |
insert! | 16 | 16 | 16 | 0.0276 | 16 | 16 | 0.0276 |
insert! | 18 | 18 | 18 | 0.0276 | 18 | 18 | 0.0276 |
insert! | 20 | 20 | 20 | 0.0276 | 20 | 20 | 0.0276 |
insert! | 22 | 22 | 22 | 0.0336 | 22 | 22 | 0.0336 |
insert! | 24 | 24 | 24 | 0.0336 | 24 | 24 | 0.0336 |
insert! | 26 | 26 | 26 | 0.0336 | 26 | 26 | 0.0336 |
insert! | 28 | 28 | 28 | 0.0336 | 28 | 28 | 0.0336 |
insert! | 30 | 30 | 30 | 0.0336 | 30 | 30 | 0.0336 |
insert! | 32 | 32 | 32 | 0.0336 | 32 | 32 | 0.0336 |
insert! | 34 | 34 | 34 | 0.0336 | 34 | 34 | 0.0336 |
insert! | 36 | 36 | 36 | 0.0336 | 36 | 36 | 0.0336 |
insert! | 38 | 38 | 38 | 0.0336 | 38 | 38 | 0.0336 |
insert! | 40 | 40 | 40 | 0.0336 | 40 | 40 | 0.0336 |
insert! | 42 | 42 | 42 | 0.0336 | 42 | 42 | 0.0336 |
insert! | 44 | 44 | 44 | 0.0336 | 44 | 44 | 0.0336 |
insert! | 46 | 46 | 46 | 0.0336 | 46 | 46 | 0.0336 |
insert! | 48 | 48 | 48 | 0.0336 | 48 | 48 | 0.0336 |
custom! |
Note! Use custom insert at the end of the table to insert custom components with other dimensions.
If internal details are important for your application - modify the component after inserted by selecting
the internal faces,
right clicking, and using the Intersecting tool - remove all unwanted faces and lines.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
