Home  > HVAC  > Duct Work Tees  >
Duct Work Tees - 45 degrees
Duct work tees 45 degrees - metric units
piping tee
Nominal Diameter Run Diameter Run Run Thickness Outlet Diameter Outlet Outlet Thickness
mm mm mm mm mm mm mm
insert! 60 63 63 1 63 63 1
insert! 80 80 80 1 80 80 1
insert! 100 100 100 1 100 100 1
insert! 125 125 125 1 125 125 1
insert! 160 160 160 1 160 160 1
insert! 200 200 200 1 200 200 1
insert! 250 250 250 1 250 250 1
insert! 315 315 315 1 315 315 1
insert! 400 400 400 1 400 400 1
insert! 500 500 500 1 500 500 1
insert! 630 630 630 1 630 630 1
insert! 800 800 800 1 800 800 1
insert! 1000 1000 1000 1 1000 1000 1
insert! 1250 1250 1250 1 1250 1250 1
custom!
Length
Color
Offset
Note! Use custom insert at the end of the table to insert custom components with other dimensions.
If internal details are important for your application - modify the component after inserted by selecting the internal faces,
right clicking, and using the Intersecting tool - remove all unwanted faces and lines.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
