Sign in!
Home > Piping > Pipes and Tubes >
Copper Tubes - Type A
Dimensions and weights of copper tubes type A - metric units (mm)
copper tube type a
Nominal DiameterOutside DiameterInside DiameterWall ThicknessWeightInside Area
mmmmmmmmkg/mmm**2
insert!664.40.80.11715
insert!886.20.90.17930
insert!10108.20.90.2353
insert!12129.61.20.36472
insert!151512.61.20.465125
insert!181815.61.20.566191
insert!222218.81.60.917277
insert!282824.81.61.19483
insert!353531.81.61.5794
insert!424238.41.82.031158
insert!545449.82.13.061947
insert!676762.22.44.353037
insert!797973.42.85.994229
insert!10510598.23.49.77570
insert!130130122414.211684
insert!156156146.44.820.316825
insert!206206192.46.83829059
insert!2572572408.559.345216
insert!308308287.410.386.164840
custom!
mmmmmmmmkg/mmm**2
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 20
