Home
Function Curves
Add concentric spirals to the model
Input the maximum outside diameter, the minimum innside diameter, the horizontal distance between the turns and the elevation added by each turn.
Input the number of segments. More segments for smoother curves and better approximation to real curve length.
Summarized Length of Curve Segments |
Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
and more.
5 3
