Butt welded concentric reducers
| Nominal Diameter | Large Diameter | Small Diameter | Run | Thickness | |
| in | in | in | in | in | |
| insert! | 3/4 x 3/8 | 1.05 | 0.680 | 1.50 | 0.113 |
| insert! | 3/4 x 1/2 | 1.05 | 0.840 | 1.50 | 0.113 |
| insert! | 1 x 3/4 | 1.315 | 1.05 | 2.00 | 0.113 |
| insert! | 1 x 1/2 | 1.315 | 0.840 | 2.00 | 0.113 |
| insert! | 1 1/4 x 1 | 1.66 | 1.315 | 2.00 | 0.140 |
| insert! | 1 1/4 x 3/4 | 1.66 | 1.05 | 2.00 | 0.140 |
| insert! | 1 1/4 x 1/2 | 1.66 | 0.840 | 2.00 | 0.140 |
| insert! | 1 1/2 x 1 1/4 | 1.90 | 1.66 | 2.50 | 0.145 |
| insert! | 1 1/2 x 1 | 1.90 | 1.315 | 2.50 | 0.145 |
| insert! | 1 1/2 x 3/4 | 1.90 | 1.05 | 2.50 | 0.145 |
| insert! | 1 1/2 x 1/2 | 1.90 | 0.840 | 2.50 | 0.145 |
| insert! | 2 x 1 1/2 | 2.375 | 1.90 | 3.00 | 0.154 |
| insert! | 2 x 1 1/4 | 2.375 | 1.66 | 3.00 | 0.154 |
| insert! | 2 x 1 | 2.375 | 1.315 | 3.00 | 0.154 |
| insert! | 2 x 3/4 | 2.375 | 1.05 | 3.00 | 0.154 |
| insert! | 2 1/2 x 2 | 2.875 | 2.375 | 3.50 | 0.203 |
| insert! | 2 1/2 x 1 1/2 | 2.875 | 1.90 | 3.50 | 0.203 |
| insert! | 2 1/2 x 1 1/4 | 2.875 | 1.66 | 3.50 | 0.203 |
| insert! | 2 1/2 x 1 | 2.875 | 1.315 | 3.50 | 0.203 |
| insert! | 3 x 2 1/2 | 3.50 | 2.875 | 3.50 | 0.216 |
| insert! | 3 x 2 | 3.50 | 2.375 | 3.50 | 0.216 |
| insert! | 3 x 1 1/2 | 3.50 | 1.90 | 3.50 | 0.216 |
| insert! | 3 x 1 1/4 | 3.50 | 1.66 | 3.50 | 0.216 |
| insert! | 3 1/2 x 3 | 4.00 | 3.50 | 4.00 | 0.226 |
| insert! | 3 1/2 x 2 1/2 | 4.00 | 2.875 | 4.00 | 0.226 |
| insert! | 3 1/2 x 2 | 4.00 | 2.375 | 4.00 | 0.226 |
| insert! | 3 1/2 x 1 1/2 | 4.00 | 1.90 | 4.00 | 0.226 |
| insert! | 3 1/2 x 1 1/4 | 4.00 | 1.66 | 4.00 | 0.226 |
| insert! | 4 x 3 1/2 | 4.50 | 4.00 | 4.00 | 0.237 |
| insert! | 4 x 3 | 4.50 | 3.50 | 4.00 | 0.237 |
| insert! | 4 x 2 1/2 | 4.50 | 2.875 | 4.00 | 0.237 |
| insert! | 4 x 2 | 4.50 | 2.375 | 4.00 | 0.237 |
| insert! | 4 x 1 1/2 | 4.50 | 1.90 | 4.00 | 0.237 |
| insert! | 5 x 4 | 5.563 | 4.50 | 5.00 | 0.258 |
| insert! | 5 x 3 1/2 | 5.563 | 4.00 | 5.00 | 0.258 |
| insert! | 5 x 3 | 5.563 | 3.50 | 5.00 | 0.258 |
| insert! | 5 x 2 1/2 | 5.563 | 2.875 | 5.00 | 0.258 |
| insert! | 5 x 2 | 5.563 | 2.375 | 5.00 | 0.258 |
| insert! | 6 x 5 | 6.625 | 5.563 | 5.50 | 0.280 |
| insert! | 6 x 4 | 6.625 | 4.50 | 5.50 | 0.280 |
| insert! | 6 x 3 1/2 | 6.625 | 4.00 | 5.50 | 0.280 |
| insert! | 6 x 3 | 6.625 | 3.50 | 5.50 | 0.280 |
| insert! | 6 x 2 1/2 | 6.625 | 2.875 | 5.50 | 0.280 |
| insert! | 8 x 6 | 8.625 | 6.625 | 6.00 | 0.322 |
| insert! | 8 x 5 | 8.625 | 5.563 | 6.00 | 0.322 |
| insert! | 8 x 4 | 8.625 | 4.50 | 6.00 | 0.322 |
| insert! | 8 x 3 1/2 | 8.625 | 4.00 | 6.00 | 0.322 |
| insert! | 10 x 8 | 10.75 | 8.625 | 7.00 | 0.365 |
| insert! | 10 x 6 | 10.75 | 6.625 | 7.00 | 0.365 |
| insert! | 10 x 5 | 10.75 | 5.563 | 7.00 | 0.365 |
| insert! | 10 x 4 | 10.75 | 4.50 | 7.00 | 0.365 |
| insert! | 12 x 10 | 12.75 | 10.75 | 8.00 | 0.375 |
| insert! | 12 x 8 | 12.75 | 8.625 | 8.00 | 0.375 |
| insert! | 12 x 6 | 12.75 | 6.625 | 8.00 | 0.375 |
| insert! | 12 x 5 | 12.75 | 5.563 | 8.00 | 0.375 |
| insert! | 14 x 12 | 14.00 | 12.75 | 13.00 | 0.375 |
| insert! | 14 x 10 | 14.00 | 10.75 | 13.00 | 0.375 |
| insert! | 14 x 8 | 14.00 | 8.625 | 13.00 | 0.375 |
| insert! | 14 x 6 | 14.00 | 6.625 | 13.00 | 0.375 |
| insert! | 16 x 14 | 16.00 | 14.00 | 14.00 | 0.375 |
| insert! | 16 x 12 | 16.00 | 12.75 | 14.00 | 0.375 |
| insert! | 16 x 10 | 16.00 | 10.75 | 14.00 | 0.375 |
| insert! | 16 x 8 | 16.00 | 8.625 | 14.00 | 0.375 |
| insert! | 18 x 16 | 18.00 | 16.00 | 15.00 | 0.375 |
| insert! | 18 x 14 | 18.00 | 14.00 | 15.00 | 0.375 |
| insert! | 18 x 12 | 18.00 | 12.75 | 15.00 | 0.375 |
| insert! | 18 x 10 | 18.00 | 10.75 | 15.00 | 0.375 |
| insert! | 20 x 18 | 20.00 | 18.00 | 20.00 | 0.375 |
| insert! | 20 x 16 | 20.00 | 16.00 | 20.00 | 0.375 |
| insert! | 20 x 14 | 20.00 | 14.00 | 20.00 | 0.375 |
| insert! | 20 x 12 | 20.00 | 12.75 | 20.00 | 0.375 |
| insert! | 22 x 20 | 22.00 | 20.00 | 20.00 | 0.375 |
| insert! | 22 x 18 | 22.00 | 18.00 | 20.00 | 0.375 |
| insert! | 22 x 16 | 22.00 | 16.00 | 20.00 | 0.375 |
| insert! | 22 x 14 | 22.00 | 14.00 | 20.00 | 0.375 |
| insert! | 24 x 22 | 24.00 | 22.00 | 20.00 | 0.375 |
| insert! | 24 x 20 | 24.00 | 20.00 | 20.00 | 0.375 |
| insert! | 24 x 18 | 24.00 | 18.00 | 20.00 | 0.375 |
| insert! | 24 x 16 | 24.00 | 16.00 | 20.00 | 0.375 |
| insert! | 26 x 24 | 26.00 | 24.00 | 24.00 | 0.375 |
| insert! | 26 x 22 | 26.00 | 22.00 | 24.00 | 0.375 |
| insert! | 26 x 20 | 26.00 | 20.00 | 24.00 | 0.375 |
| insert! | 26 x 18 | 26.00 | 18.00 | 24.00 | 0.375 |
| insert! | 28 x 26 | 28.00 | 26.00 | 24.00 | 0.375 |
| insert! | 28 x 24 | 28.00 | 24.00 | 24.00 | 0.375 |
| insert! | 28 x 22 | 28.00 | 22.00 | 24.00 | 0.375 |
| insert! | 28 x 20 | 28.00 | 20.00 | 24.00 | 0.375 |
| insert! | 28 x 18 | 28.00 | 18.00 | 24.00 | 0.375 |
| insert! | 30 x 28 | 30.00 | 28.00 | 24.00 | 0.375 |
| insert! | 30 x 26 | 30.00 | 26.00 | 24.00 | 0.375 |
| insert! | 30 x 24 | 30.00 | 24.00 | 24.00 | 0.375 |
| insert! | 30 x 22 | 30.00 | 22.00 | 24.00 | 0.375 |
| insert! | 30 x 20 | 30.00 | 20.00 | 24.00 | 0.375 |
| insert! | 32 x 30 | 32.00 | 30.00 | 24.00 | 0.375 |
| insert! | 32 x 28 | 32.00 | 28.00 | 24.00 | 0.375 |
| insert! | 32 x 26 | 32.00 | 26.00 | 24.00 | 0.375 |
| insert! | 32 x 24 | 32.00 | 24.00 | 24.00 | 0.375 |
| insert! | 34 x 32 | 34.00 | 32.00 | 24.00 | 0.375 |
| insert! | 34 x 30 | 34.00 | 30.00 | 24.00 | 0.375 |
| insert! | 34 x 28 | 34.00 | 28.00 | 24.00 | 0.375 |
| insert! | 34 x 26 | 34.00 | 26.00 | 24.00 | 0.375 |
| insert! | 34 x 24 | 34.00 | 24.00 | 24.00 | 0.375 |
| insert! | 36 x 34 | 36.00 | 34.00 | 24.00 | 0.375 |
| insert! | 36 x 32 | 36.00 | 32.00 | 24.00 | 0.375 |
| insert! | 36 x 30 | 36.00 | 30.00 | 24.00 | 0.375 |
| insert! | 36 x 26 | 36.00 | 26.00 | 24.00 | 0.375 |
| insert! | 36 x 24 | 36.00 | 24.00 | 24.00 | 0.375 |
| insert! | 38 x 36 | 38.00 | 36.00 | 24.00 | 0.375 |
| insert! | 38 x 34 | 38.00 | 34.00 | 24.00 | 0.375 |
| insert! | 38 x 32 | 38.00 | 32.00 | 24.00 | 0.375 |
| insert! | 38 x 30 | 38.00 | 30.00 | 24.00 | 0.375 |
| insert! | 38 x 28 | 38.00 | 28.00 | 24.00 | 0.375 |
| insert! | 38 x 26 | 38.00 | 26.00 | 24.00 | 0.375 |
| insert! | 40 x 38 | 40.00 | 38.00 | 24.00 | 0.375 |
| insert! | 40 x 36 | 40.00 | 36.00 | 24.00 | 0.375 |
| insert! | 40 x 34 | 40.00 | 34.00 | 24.00 | 0.375 |
| insert! | 40 x 32 | 40.00 | 32.00 | 24.00 | 0.375 |
| insert! | 40 x 30 | 40.00 | 30.00 | 24.00 | 0.375 |
| insert! | 42 x 40 | 42.00 | 40.00 | 24.00 | 0.375 |
| insert! | 42 x 38 | 42.00 | 38.00 | 24.00 | 0.375 |
| insert! | 42 x 36 | 42.00 | 36.00 | 24.00 | 0.375 |
| insert! | 42 x 34 | 42.00 | 34.00 | 24.00 | 0.375 |
| insert! | 42 x 32 | 42.00 | 32.00 | 24.00 | 0.375 |
| insert! | 42 x 30 | 42.00 | 30.00 | 24.00 | 0.375 |
| insert! | 44 x 42 | 44.00 | 42.00 | 24.00 | 0.375 |
| insert! | 44 x 40 | 44.00 | 40.00 | 24.00 | 0.375 |
| insert! | 44 x 38 | 44.00 | 38.00 | 24.00 | 0.375 |
| insert! | 44 x 36 | 44.00 | 36.00 | 24.00 | 0.375 |
| insert! | 46 x 44 | 46.00 | 44.00 | 28.00 | 0.375 |
| insert! | 46 x 42 | 46.00 | 42.00 | 28.00 | 0.375 |
| insert! | 46 x 40 | 46.00 | 40.00 | 28.00 | 0.375 |
| insert! | 46 x 38 | 46.00 | 38.00 | 28.00 | 0.375 |
| insert! | 48 x 46 | 48.00 | 46.00 | 28.00 | 0.375 |
| insert! | 48 x 44 | 48.00 | 44.00 | 28.00 | 0.375 |
| insert! | 48 x 42 | 48.00 | 42.00 | 28.00 | 0.375 |
| insert! | 48 x 40 | 48.00 | 40.00 | 28.00 | 0.375 |
| custom! | |||||
Note! Outside diameters and dimensions are correct for all schedules. Thickness are based on standard schedules. Use custom insert at the end of the table to insert custom components with other schedules.
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 14
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
