Sign in!
Home > HVAC > Duct Work - Elbows >
Bended Duct - Customized Angles and Dimensions
Add bend or elbows with custom dimensions
pipe elbow bend
More segments makes smoother curves.
outside diameter
wall thickness
radius
angle
number of segments
Insert!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
