Sign in!
Home > Piping > Elbows and Bends >
Bended Pipe or Tube - Customized Angles and Dimensions
Add bend or elbows with custom dimensions
bended pipe tube - customized
Add customized bends or elbows to your Sketchup model.
Change the parameters and select "Insert!"
More segments makes smoother bends.
outside diameter
wall thickness
radius
angle
number of segments
Insert!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
