Butt welded straight crosses
Note! Outside diameters and dimensions are correct for all schedules.
Thickness are based on standard schedules. Use custom insert at the end of the table to insert custom components with other schedules.
If internal details are important for your application - modify the component after inserted by selecting the internal faces,
right clicking, and using the Intersecting tool - remove all unwanted faces and lines.
| Nominal Diameter | Run Diameter | Run | Run Thickness | Outlet Diameter | Outlet | Outlet Thickness | |
| in | in | in | in | in | in | in | |
| insert! | 1/2 | 0.840 | 1.000 | 0.109 | 0.840 | 1.000 | 0.109 |
| insert! | 3/4 | 1.050 | 1.125 | 0.113 | 1.050 | 1.125 | 0.133 |
| insert! | 1 | 1.315 | 1.500 | 0.133 | 1.315 | 1.50 | 0.133 |
| insert! | 1 1/4 | 1.660 | 1.875 | 0.140 | 1.660 | 1.875 | 0.140 |
| insert! | 1 1/2 | 1.900 | 2.250 | 0.145 | 1.900 | 2.25 | 0.145 |
| insert! | 2 | 2.375 | 2.500 | 0.154 | 2.375 | 2.50 | 0.154 |
| insert! | 2 1/2 | 2.875 | 3.000 | 0.203 | 2.875 | 3.00 | 0.203 |
| insert! | 3 | 3.500 | 3.375 | 0.216 | 3.500 | 3.375 | 0.216 |
| insert! | 3 1/2 | 4.000 | 3.750 | 0.226 | 4.000 | 3.75 | 0.226 |
| insert! | 4 | 4.500 | 4.125 | 0.237 | 4.500 | 4.125 | 0.237 |
| insert! | 5 | 5.563 | 4.875 | 0.258 | 5.563 | 4.875 | 0.258 |
| insert! | 6 | 6.625 | 5.625 | 0.280 | 6.625 | 5.625 | 0.280 |
| insert! | 8 | 8.625 | 7.00 | 0.322 | 8.625 | 7.00 | 0.322 |
| insert! | 10 | 10.750 | 8.500 | 0.365 | 10.750 | 8.50 | 0.365 |
| insert! | 12 | 12.750 | 10.00 | 0.375 | 12.750 | 10.00 | 0.375 |
| insert! | 14 | 14.000 | 11.00 | 0.375 | 14.000 | 11.00 | 0.375 |
| insert! | 16 | 16.000 | 12.00 | 0.375 | 16.000 | 12.00 | 0.375 |
| insert! | 18 | 18.000 | 13.50 | 0.375 | 18.000 | 13.50 | 0.375 |
| insert! | 20 | 20.000 | 15.00 | 0.375 | 20.000 | 15.00 | 0.375 |
| insert! | 22 | 22.000 | 16.50 | 0.375 | 22.000 | 16.50 | 0.375 |
| insert! | 24 | 24.000 | 17.00 | 0.375 | 24.000 | 17.00 | 0.375 |
| insert! | 26 | 26.000 | 19.50 | 0.375 | 26.000 | 19.50 | 0.375 |
| insert! | 28 | 28.000 | 20.50 | 0.375 | 28.000 | 20.50 | 0.375 |
| insert! | 30 | 30.000 | 22.00 | 0.375 | 30.000 | 22.00 | 0.375 |
| insert! | 32 | 32.000 | 23.50 | 0.375 | 32.000 | 23.50 | 0.375 |
| insert! | 34 | 34.000 | 25.00 | 0.375 | 34.000 | 25.00 | 0.375 |
| insert! | 36 | 36.000 | 26.50 | 0.375 | 36.000 | 26.50 | 0.375 |
| insert! | 38 | 38.000 | 28.00 | 0.375 | 38.000 | 28.00 | 0.375 |
| insert! | 40 | 40.000 | 29.50 | 0.375 | 40.000 | 29.50 | 0.375 |
| insert! | 42 | 42.000 | 30.00 | 0.375 | 42.000 | 28.00 | 0.375 |
| insert! | 44 | 44.000 | 32.00 | 0.375 | 44.000 | 30.00 | 0.375 |
| insert! | 46 | 46.000 | 33.50 | 0.375 | 46.000 | 31.50 | 0.375 |
| insert! | 48 | 48.000 | 35.00 | 0.375 | 48.000 | 33.00 | 0.375 |
| custom! | |||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 8
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
