Home
HVAC
Duct Work Tees
Air duct tees - Metric units
Nominal Diameter | Run Diameter | Run | Run Thickness | Outlet Diameter | Outlet | Outlet Thickness | |
mm | mm | mm | mm | mm | mm | mm | |
insert! | 60 | 63 | 63 | 1 | 63 | 63 | 1 |
insert! | 80 | 80 | 80 | 1 | 80 | 80 | 1 |
insert! | 100 | 100 | 100 | 1 | 100 | 100 | 1 |
insert! | 125 | 125 | 125 | 1 | 125 | 125 | 1 |
insert! | 160 | 160 | 160 | 1 | 160 | 160 | 1 |
insert! | 200 | 200 | 200 | 1 | 200 | 200 | 1 |
insert! | 250 | 250 | 250 | 1 | 250 | 250 | 1 |
insert! | 315 | 315 | 315 | 1 | 315 | 315 | 1 |
insert! | 400 | 400 | 400 | 1 | 400 | 400 | 1 |
insert! | 500 | 500 | 500 | 1 | 500 | 500 | 1 |
insert! | 630 | 630 | 630 | 1 | 630 | 630 | 1 |
insert! | 800 | 800 | 800 | 1 | 800 | 800 | 1 |
insert! | 1000 | 1000 | 1000 | 1 | 1000 | 1000 | 1 |
insert! | 1250 | 1250 | 1250 | 1 | 1250 | 1250 | 1 |
custom! |
Note! Use custom insert at the end of the table to insert custom components with other dimensions.
If internal details are important for your application - modify the component after inserted by selecting
the internal faces,
right clicking, and using the Intersecting tool - remove all unwanted faces and lines.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
