I-shaped engineered wood structural members
Designation |
Depth mm |
Width mm |
Thickness Web mm |
Thickness Flange mm |
insert! | 200 x 47 | 200 | 47 | 10 | 47 |
insert! | 250 x 47 | 250 | 47 | 10 | 47 |
insert! | 300 x 47 | 300 | 47 | 10 | 47 |
insert! | 350 x 47 | 350 | 47 | 10 | 47 |
insert! | 250 x 70 | 250 | 70 | 10 | 47 |
insert! | 300 x 70 | 300 | 70 | 10 | 47 |
insert! | 350 x 70 | 350 | 70 | 10 | 47 |
insert! | 400 x 70 | 400 | 70 | 10 | 47 |
insert! | 300 x 97 | 300 | 97 | 10 | 47 |
insert! | 350 x 97 | 350 | 97 | 10 | 47 |
insert! | 400 x 97 | 400 | 97 | 10 | 47 |
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
and more.
5 3
