I-shaped engineered wood structural members
Designation |
Depth in |
Width in |
Thickness Web in |
Thickness Flange in |
insert! | 9 1/2 x 1 3/4 | 9.5 | 1.75 | 0.375 | 1.375 |
insert! | 11 7/8 x 1 3/4 | 11.875 | 1.75 | 0.375 | 1.375 |
insert! | 14 x 1 3/4 | 14 | 1.75 | 0.375 | 1.375 |
insert! | 16 x 1 3/4 | 16 | 1.75 | 0.375 | 1.375 |
insert! | 9 1/2 x 2 1/16 | 9.5 | 2.0625 | 0.375 | 1.375 |
insert! | 11 7/8 x 2 1/16 | 11.875 | 2.0625 | 0.375 | 1.375 |
insert! | 14 x 2 1/16 | 14 | 2.0625 | 0.375 | 1.375 |
insert! | 16 x 2 1/16 | 16 | 2.0625 | 0.375 | 1.375 |
insert! | 9 1/2 x 2 5/16 | 9.5 | 2.3125 | 0.375 | 1.375 |
insert! | 11 7/8 x 2 5/16 | 11.875 | 2.3125 | 0.375 | 1.375 |
insert! | 14 x 2 5/16 | 14 | 2.3125 | 0.375 | 1.375 |
insert! | 16 x 2 5/16 | 16 | 2.3125 | 0.375 | 1.375 |
insert! | 9 1/2 x 3 1/2 | 9.5 | 3.5 | 0.4375 | 1.375 |
insert! | 11 7/8 x 3 1/2 | 11.875 | 3.5 | 0.4375 | 1.375 |
insert! | 14 x 3 1/2 | 14 | 3.5 | 0.4375 | 1.375 |
insert! | 16 x 3 1/2 | 16 | 3.5 | 0.4375 | 1.375 |
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
and more.
5 3
