Pipes conforming to IS: 3589-2001 - metric units (mm)
| Nominal Bore | Nominal Bore | Outside Diameter | Inside Diameter | Wall Thickness | Mass | |
| in | mm | mm | mm | mm | kg/m | |
| insert! | 6 | 150 | 168.3 | 158.7 | 4.8 | 19.3 |
| insert! | 6 | 150 | 168.3 | 158.3 | 5.0 | 20.1 |
| insert! | 6 | 150 | 168.3 | 157.5 | 5.4 | 21.7 |
| insert! | 6 | 150 | 168.3 | 156.3 | 6.0 | 24.0 |
| insert! | 6 | 150 | 168.3 | 155.5 | 6.4 | 25.5 |
| insert! | 6 | 150 | 168.3 | 154.3 | 7.0 | 27.8 |
| insert! | 6 | 150 | 168.3 | 152.3 | 8.0 | 31.6 |
| insert! | 8 | 175 | 193.7 | 184.1 | 4.8 | 22.6 |
| insert! | 8 | 175 | 193.7 | 183.7 | 5.0 | 23.3 |
| insert! | 8 | 175 | 193.7 | 182.9 | 5.4 | 25.1 |
| insert! | 8 | 175 | 193.7 | 181.7 | 6.0 | 27.8 |
| insert! | 8 | 175 | 193.7 | 180.9 | 6.4 | 29.6 |
| insert! | 8 | 175 | 193.7 | 179.7 | 7.0 | 32.2 |
| insert! | 8 | 175 | 193.7 | 177.7 | 8.0 | 36.6 |
| insert! | 8 | 175 | 193.7 | 174.7 | 9.5 | 43.2 |
| insert! | 10 | 200 | 219.1 | 210.5 | 4.3 | 22.8 |
| insert! | 10 | 200 | 219.1 | 209.5 | 4.8 | 25.6 |
| insert! | 10 | 200 | 219.1 | 209.1 | 5.0 | 26.4 |
| insert! | 10 | 200 | 219.1 | 208.3 | 5.4 | 28.5 |
| insert! | 10 | 200 | 219.1 | 207.1 | 6.0 | 31.5 |
| insert! | 10 | 200 | 219.1 | 206.3 | 6.4 | 33.6 |
| insert! | 10 | 200 | 219.1 | 205.1 | 7.0 | 36.6 |
| insert! | 10 | 200 | 219.1 | 203.1 | 8.0 | 41.6 |
| insert! | 10 | 200 | 219.1 | 200.1 | 9.5 | 49.1 |
| insert! | 12 | 250 | 273 | 264.4 | 4.3 | 28.5 |
| insert! | 12 | 250 | 273 | 263.4 | 4.8 | 32.1 |
| insert! | 12 | 250 | 273 | 263 | 5.0 | 33.0 |
| insert! | 12 | 250 | 273 | 262.2 | 5.4 | 35.6 |
| insert! | 12 | 250 | 273 | 261 | 6.0 | 39.5 |
| insert! | 12 | 250 | 273 | 260.2 | 6.4 | 42.1 |
| insert! | 12 | 250 | 273 | 259 | 7.0 | 45.9 |
| insert! | 12 | 250 | 273 | 257 | 8.0 | 52.3 |
| insert! | 12 | 250 | 273 | 254.3 | 9.4 | 61.7 |
| custom! | ||||||
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 22
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
