BSI BS 4-1 - Properties of British Universal Beams - Metric Units
| Designation | Depth | Width | Thickness Web | Thickness Flange | Root Radius | Depth between fillets | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| mm | mm | mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | cm**3 | cm**3 | ||
| insert! | UB 127 x 76 x 13 | 127 | 76 | 4 | 7.6 | 7.6 | 96.6 | 16.5 | 13 | 473 | 55.7 | 74.6 | 14.7 |
| insert! | UB 152 x 89 x 16 | 152.4 | 88.7 | 4.5 | 7.7 | 7.6 | 121.8 | 20.3 | 16 | 834 | 89.8 | 109 | 20.2 |
| insert! | UB 178 x 102 x 19 | 177.8 | 101.2 | 4.8 | 7.9 | 7.6 | 146.8 | 24.3 | 19 | 1356 | 137 | 153 | 27 |
| insert! | UB 203 x 102 x 23 | 203.2 | 101.8 | 5.4 | 9.3 | 7.6 | 169.4 | 29.4 | 23.1 | 2105 | 164 | 207 | 32.2 |
| insert! | UB 203 x 133 x 25 | 203.2 | 133.2 | 5.7 | 7.8 | 7.6 | 172.4 | 32 | 25.1 | 2340 | 308 | 230 | 46.2 |
| insert! | UB 203 x 133 x 30 | 206.8 | 133.9 | 6.4 | 9.6 | 7.6 | 172.4 | 38.2 | 30 | 2896 | 385 | 280 | 57.5 |
| insert! | UB 254 x 102 x 22 | 254 | 101.6 | 5.7 | 6.8 | 7.6 | 225.2 | 28 | 22 | 2841 | 119 | 224 | 23.5 |
| insert! | UB 254 x 102 x 25 | 257.2 | 101.9 | 6 | 8.4 | 7.6 | 225.2 | 32 | 25.2 | 3415 | 149 | 266 | 29.2 |
| insert! | UB 254 x 102 x 28 | 260.4 | 102.2 | 6.3 | 10 | 7.6 | 225.2 | 36.1 | 28.3 | 4005 | 179 | 308 | 34.9 |
| insert! | UB 254 x 146 x 31 | 251.4 | 146.1 | 6 | 8.6 | 7.6 | 219 | 39.7 | 31.1 | 4413 | 448 | 351 | 61.3 |
| insert! | UB 254 x 146 x 37 | 256 | 146.4 | 6.3 | 10.9 | 7.6 | 219 | 47.2 | 37 | 5537 | 571 | 433 | 78 |
| insert! | UB 254 x 146 x 43 | 259.6 | 147.3 | 7.2 | 12.7 | 7.6 | 219 | 54.8 | 43 | 6544 | 677 | 504 | 92 |
| insert! | UB 305 x 102 x 25 | 305.1 | 101.6 | 5.8 | 7 | 7.6 | 275.9 | 31.6 | 24.8 | 4455 | 123 | 292 | 24.2 |
| insert! | UB 305 x 102 x 28 | 308.7 | 101.8 | 6 | 8.8 | 7.6 | 275.9 | 35.9 | 28.2 | 5366 | 155 | 348 | 30.5 |
| insert! | UB 305 x 102 x 33 | 312.7 | 102.4 | 6.6 | 10.8 | 7.6 | 275.9 | 41.8 | 32.8 | 6501 | 194 | 416 | 37.9 |
| insert! | UB 305 x 127 x 37 | 304.4 | 123.4 | 7.1 | 10.7 | 8.9 | 265.2 | 47.2 | 37 | 7171 | 336 | 471 | 54.5 |
| insert! | UB 305 x 127 x 42 | 307.2 | 124.3 | 8 | 12.1 | 8.9 | 265.2 | 53.4 | 41.9 | 8196 | 389 | 534 | 62.6 |
| insert! | UB 305 x 127 x 48 | 311 | 125.3 | 9 | 14 | 8.9 | 265.2 | 61.2 | 48.1 | 9575 | 461 | 616 | 73.6 |
| insert! | UB 305 x 165 x 40 | 303.4 | 165 | 6 | 10.2 | 8.9 | 265.2 | 51.3 | 40.3 | 8503 | 764 | 560 | 92.6 |
| insert! | UB 305 x 165 x 46 | 306.6 | 165.7 | 6.7 | 11.8 | 8.9 | 265.2 | 58.7 | 46.1 | 9899 | 896 | 646 | 108 |
| insert! | UB 305 x 165 x 54 | 310.4 | 166.9 | 7.9 | 13.7 | 8.9 | 265.2 | 68.8 | 54 | 11696 | 1063 | 754 | 127 |
| insert! | UB 356 x 127 x 33 | 349 | 125.4 | 6 | 8.5 | 10.2 | 311.6 | 42.1 | 33.1 | 8249 | 280 | 473 | 44.7 |
| insert! | UB 356 x 127 x 39 | 353.4 | 126 | 6.6 | 10.7 | 10.2 | 311.6 | 49.8 | 39.1 | 10172 | 358 | 576 | 56.8 |
| insert! | UB 356 x 171 x 45 | 351.4 | 171.1 | 7 | 9.7 | 10.2 | 311.6 | 57.3 | 45 | 12066 | 811 | 687 | 94.8 |
| insert! | UB 356 x 171 x 51 | 355 | 171.5 | 7.4 | 11.5 | 10.2 | 311.6 | 64.9 | 51 | 14136 | 968 | 796 | 113 |
| insert! | UB 356 x 171 x 57 | 358 | 172.2 | 8.1 | 13 | 10.2 | 311.6 | 72.6 | 57 | 16038 | 1108 | 896 | 129 |
| insert! | UB 356 x 171 x 67 | 363.4 | 173.2 | 9.1 | 15.7 | 10.2 | 311.6 | 85.5 | 67.1 | 19463 | 1362 | 1071 | 157 |
| insert! | UB 406 x 140 x 39 | 398 | 141.8 | 6.4 | 8.6 | 10.2 | 360.4 | 49.7 | 39 | 12508 | 410 | 629 | 57.8 |
| insert! | UB 406 x 140 x 46 | 403.2 | 142.2 | 6.8 | 11.2 | 10.2 | 360.4 | 58.6 | 46 | 15685 | 538 | 778 | 75.7 |
| insert! | UB 406 x 178 x 54 | 402.6 | 177.7 | 7.7 | 10.9 | 10.2 | 360.4 | 69 | 54.1 | 18722 | 1021 | 930 | 115 |
| insert! | UB 406 x 178 x 60 | 406.4 | 177.9 | 7.9 | 12.8 | 10.2 | 360.4 | 76.5 | 60.1 | 21596 | 1203 | 1063 | 135 |
| insert! | UB 406 x 178 x 67 | 409.4 | 178.8 | 8.8 | 14.3 | 10.2 | 360.4 | 85.5 | 67.1 | 24331 | 1365 | 1189 | 153 |
| insert! | UB 406 x 178 x 74 | 412.8 | 179.5 | 9.5 | 16 | 10.2 | 360.4 | 94.5 | 74.2 | 27310 | 1545 | 1323 | 172 |
| insert! | UB 457 x 152 x 52 | 449.8 | 152.4 | 7.6 | 10.9 | 10.2 | 407.6 | 66.6 | 52.3 | 21369 | 645 | 950 | 84.6 |
| insert! | UB 457 x 152 x 60 | 454.6 | 152.9 | 8.1 | 13.3 | 10.2 | 407.6 | 76.2 | 59.8 | 25500 | 795 | 1122 | 104 |
| insert! | UB 457 x 152 x 67 | 458 | 153.8 | 9 | 15 | 10.2 | 407.6 | 85.6 | 67.2 | 28927 | 913 | 1263 | 119 |
| insert! | UB 457 x 152 x 74 | 462 | 154.4 | 9.6 | 17 | 10.2 | 407.6 | 94.5 | 74.2 | 32674 | 1047 | 1414 | 136 |
| insert! | UB 457 x 152 x 82 | 465.8 | 155.3 | 10.5 | 18.9 | 10.2 | 407.6 | 105 | 82.1 | 36589 | 1185 | 1571 | 153 |
| insert! | UB 457 x 191 x 67 | 453.4 | 189.9 | 8.5 | 12.7 | 10.2 | 407.6 | 85.5 | 67.1 | 29380 | 1452 | 1296 | 153 |
| insert! | UB 457 x 191 x 74 | 457 | 190.4 | 9 | 14.5 | 10.2 | 407.6 | 94.6 | 74.3 | 33319 | 1671 | 1458 | 176 |
| insert! | UB 457 x 191 x 82 | 460 | 191.3 | 9.9 | 16 | 10.2 | 407.6 | 104 | 82 | 37051 | 1871 | 1611 | 196 |
| insert! | UB 457 x 191 x 89 | 463.4 | 191.9 | 10.5 | 17.7 | 10.2 | 407.6 | 114 | 89.3 | 41015 | 2089 | 1770 | 218 |
| insert! | UB 457 x 191 x 98 | 467.2 | 192.8 | 11.4 | 19.6 | 10.2 | 407.6 | 125 | 98.3 | 45727 | 2347 | 1957 | 243 |
| insert! | UB 533 x 210 x 101 | 536.7 | 210 | 10.8 | 17.4 | 12.7 | 476.5 | 129 | 101 | 61519 | 2692 | 2292 | 256 |
| insert! | UB 533 x 210 x 109 | 539.5 | 210.8 | 11.6 | 18.8 | 12.7 | 476.5 | 139 | 109 | 66822 | 2943 | 2477 | 279 |
| insert! | UB 533 x 210 x 122 | 544.5 | 211.9 | 12.7 | 21.3 | 12.7 | 476.5 | 155 | 122 | 76043 | 3388 | 2793 | 256 |
| insert! | UB 533 x 210 x 82 | 528.3 | 208.8 | 9.6 | 13.2 | 12.7 | 476.5 | 105 | 82.2 | 47539 | 2007 | 1800 | 192 |
| insert! | UB 533 x 210 x 92 | 533.1 | 209.3 | 10.1 | 15.6 | 12.7 | 476.5 | 117 | 92.1 | 55227 | 2389 | 2072 | 228 |
| insert! | UB 610 x 229 x 101 | 602.6 | 227.6 | 10.5 | 14.8 | 12.7 | 547.6 | 129 | 101.2 | 75780 | 2915 | 2515 | 256 |
| insert! | UB 610 x 229 x 113 | 607.6 | 228.2 | 11.1 | 17.3 | 12.7 | 547.6 | 144 | 113 | 87318 | 3434 | 2874 | 301 |
| insert! | UB 610 x 229 x 125 | 612.2 | 229 | 11.9 | 19.6 | 12.7 | 547.6 | 159 | 125.1 | 98610 | 3932 | 3221 | 343 |
| insert! | UB 610 x 229 x 140 | 617.2 | 230.2 | 13.1 | 22.1 | 12.7 | 547.6 | 178 | 139.9 | 111777 | 4505 | 3622 | 391 |
| insert! | UB 610 x 305 x 149 | 612.4 | 304.8 | 11.8 | 19.7 | 16.5 | 540 | 190 | 149.2 | 125876 | 9308 | 4111 | 611 |
| insert! | UB 610 x 305 x 179 | 620.2 | 307.1 | 14.1 | 23.6 | 16.5 | 540 | 228 | 179 | 153024 | 11408 | 4935 | 743 |
| insert! | UB 610 x 305 x 238 | 635.8 | 311.4 | 18.4 | 31.4 | 16.5 | 540 | 303 | 238.1 | 209471 | 15837 | 6589 | 1017 |
| insert! | UB 686 x 254 x 125 | 677.9 | 253 | 11.7 | 16.2 | 15.2 | 615.1 | 159 | 125.2 | 117992 | 4383 | 3481 | 346 |
| insert! | UB 686 x 254 x 140 | 683.5 | 253.7 | 12.4 | 19 | 15.2 | 615.1 | 178 | 140.1 | 136267 | 5183 | 3987 | 409 |
| insert! | UB 686 x 254 x 152 | 687.5 | 254.5 | 13.2 | 21 | 15.2 | 615.1 | 194 | 152.4 | 150355 | 5784 | 4374 | 455 |
| insert! | UB 686 x 254 x 170 | 692.9 | 255.8 | 14.5 | 23.7 | 15.2 | 615.1 | 217 | 170.2 | 170326 | 6630 | 4916 | 518 |
| insert! | UB 762 x 267 x 134 | 750 | 264.4 | 12 | 25.5 | 16.5 | 686 | 171 | 133.9 | 150692 | 4788 | 4018 | 362 |
| insert! | UB 762 x 267 x 147 | 754 | 265.2 | 12.8 | 17.5 | 16.5 | 686 | 187 | 146.9 | 168502 | 5455 | 4470 | 411 |
| insert! | UB 762 x 267 x 173 | 762.2 | 266.7 | 14.3 | 21.6 | 16.5 | 686 | 220 | 173 | 205282 | 6850 | 5387 | 514 |
| insert! | UB 762 x 267 x 197 | 769.8 | 268 | 15.6 | 25.4 | 16.5 | 686 | 251 | 196.8 | 239957 | 8175 | 6234 | 610 |
| insert! | UB 838 x 292 x 176 | 834.9 | 291.7 | 14 | 18.8 | 17.8 | 761.7 | 224 | 175.9 | 246021 | 7799 | 5893 | 535 |
| insert! | UB 838 x 292 x 194 | 840.7 | 292.4 | 14.7 | 21.7 | 17.8 | 761.7 | 247 | 193.8 | 279175 | 9066 | 6641 | 620 |
| insert! | UB 838 x 292 x 226 | 850.9 | 293.8 | 16.1 | 26.8 | 17.8 | 761.7 | 289 | 226.5 | 339704 | 11360 | 7985 | 773 |
| insert! | UB 914 x 419 x 388 | 921 | 420.5 | 21.4 | 36.6 | 24.1 | 799.6 | 494 | 388 | 719635 | 45438 | 15627 | 2161 |
| insert! | UB 914 x 305 x 201 | 903 | 303.3 | 15.1 | 20.2 | 19.1 | 824.4 | 256 | 200.9 | 325254 | 9423 | 7204 | 621 |
| insert! | UB 914 x 305 x 224 | 910.4 | 304.1 | 15.9 | 23.9 | 19.1 | 824.4 | 286 | 224.2 | 376414 | 11236 | 8269 | 739 |
| insert! | UB 914 x 305 x 253 | 918.4 | 305.5 | 17.3 | 27.9 | 19.1 | 824.4 | 323 | 253.4 | 436305 | 13301 | 9501 | 871 |
| insert! | UB 914 x 305 x 289 | 926.6 | 307.7 | 19.5 | 32 | 19.1 | 824.4 | 368 | 289.1 | 504187 | 15597 | 10883 | 1014 |
| insert! | UB 914 x 419 x 343 | 911.8 | 418.5 | 19.4 | 32 | 24.1 | 799.6 | 437 | 343.3 | 625780 | 39156 | 13726 | 1871 |
| custom! | |||||||||||||
BSI BS 4-1 Structural Steel Sections - Part 1: Specification for Hot-Rolled Sections
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
