Home
Function Curves
Add curves based on sin and cos functions
The Trigonometric Functions sin and cos can be expressed as
y = a sin x
y = a cos x
Add a sin or cos curve to your Sketchup model!
Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
