Dimensions and weights of thermoplastic pipe schedule 80 - Imperial Dimensions
| Nominal Diameter | Outside Diameter | Inside Diameter | Wall Thickness | Weight | Inside Area | |
| in | in | in | in | lb/100 ft | in**2 | |
| insert! | 1/8 | 0.405 | 0.203 | 0.101 | 4.18 | 0.03 |
| insert! | 1/4 | 0.54 | 0.288 | 0.126 | 7.1 | 0.07 |
| insert! | 3/8 | 0.675 | 0.407 | 0.134 | 9.87 | 0.13 |
| insert! | 1/2 | 0.84 | 0.528 | 0.156 | 14.5 | 0.22 |
| insert! | 3/4 | 1.05 | 0.724 | 0.163 | 19.7 | 0.41 |
| insert! | 1 | 1.315 | 0.935 | 0.19 | 29.1 | 0.69 |
| insert! | 1 1/4 | 1.66 | 1.256 | 0.202 | 40.1 | 1.24 |
| insert! | 1 1/2 | 1.9 | 1.476 | 0.212 | 48.7 | 1.71 |
| insert! | 2 | 2.375 | 1.913 | 0.231 | 67.4 | 2.87 |
| insert! | 2 1/2 | 2.875 | 2.289 | 0.293 | 103 | 4.11 |
| insert! | 3 | 3.5 | 2.864 | 0.318 | 138 | 6.44 |
| insert! | 3 1/2 | 4 | 3.326 | 0.337 | 168 | 8.68 |
| insert! | 4 | 4.5 | 3.786 | 0.357 | 201 | 11.25 |
| insert! | 5 | 5.563 | 4.767 | 0.398 | 280 | 17.84 |
| insert! | 6 | 6.625 | 5.709 | 0.458 | 385 | 25.59 |
| insert! | 8 | 8.625 | 7.565 | 0.53 | 584 | 44.92 |
| insert! | 10 | 10.75 | 9.492 | 0.629 | 867 | 70.73 |
| insert! | 12 | 12.75 | 11.294 | 0.728 | 1192 | 100.13 |
| custom! | ||||||
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 3
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
