Home  > Function Curves  >
Straight Line
The equation for a straight line
sphere with altitude and longitude lines
A Straight Line Function can be expressed as
y = ax + b
Add a straight line curve to your Sketchup model with the tool below!
a
b
x start
x end
x diff
Insert!
Length
Color
Offset
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
