Steel tubes, tubulars conforming to IS: 1239-1990 equivalent to BS:1387-1987, IS:1161-1998 - metric units (mm)
| Nominal Bore | Nominal Bore | Weight | Outside Diameter | Inside Diameter | Wall Thickness | Mass | |
| in | mm | mm | mm | mm | kg/m | ||
| insert! | 1/4 | 8 | Light | 13.6 | 10.0 | 1.8 | 0.52 |
| insert! | 1/4 | 8 | Medium | 13.9 | 9.3 | 2.3 | 0.64 |
| insert! | 1/4 | 8 | Heavy | 13.9 | 8.1 | 2.9 | 0.77 |
| insert! | 3/8 | 10 | Light | 17.1 | 13.5 | 1.8 | 0.67 |
| insert! | 3/8 | 10 | Medium | 17.4 | 12.8 | 2.3 | 0.84 |
| insert! | 3/8 | 10 | Heavy | 17.4 | 11.6 | 2.9 | 1.02 |
| insert! | 1/2 | 15 | Light | 21.4 | 17.4 | 2.0 | 0.95 |
| insert! | 1/2 | 15 | Medium | 21.7 | 16.5 | 2.6 | 1.21 |
| insert! | 1/2 | 15 | Heavy | 21.7 | 15.3 | 3.2 | 1.44 |
| insert! | 3/4 | 20 | Light | 26.9 | 22.3 | 2.3 | 1.38 |
| insert! | 3/4 | 20 | Medium | 27.2 | 22.0 | 2.6 | 1.56 |
| insert! | 3/4 | 20 | Heavy | 27.2 | 20.8 | 3.2 | 1.87 |
| insert! | 1 | 25 | Light | 33.8 | 28.6 | 2.6 | 1.98 |
| insert! | 1 | 25 | Medium | 34.2 | 27.8 | 3.2 | 2.41 |
| insert! | 1 | 25 | Heavy | 34.2 | 26.2 | 4.0 | 2.94 |
| insert! | 1 1/4 | 32 | Light | 42.5 | 37.3 | 2.6 | 2.54 |
| insert! | 1 1/4 | 32 | Medium | 42.9 | 36.5 | 3.2 | 3.10 |
| insert! | 1 1/4 | 32 | Heavy | 42.9 | 34.9 | 4.0 | 3.80 |
| insert! | 1 1/2 | 40 | Light | 48.4 | 42.6 | 2.9 | 3.23 |
| insert! | 1 1/2 | 40 | Medium | 48.8 | 42.4 | 3.2 | 3.57 |
| insert! | 1 1/2 | 40 | Heavy | 48.8 | 40.8 | 4.0 | 4.38 |
| insert! | 2 | 50 | Light | 60.2 | 54.4 | 2.9 | 4.08 |
| insert! | 2 | 50 | Medium | 60.8 | 53.6 | 3.6 | 5.03 |
| insert! | 2 | 50 | Heavy | 60.8 | 51.8 | 4.5 | 6.19 |
| insert! | 2 1/2 | 65 | Light | 76 | 69.6 | 3.2 | 5.71 |
| insert! | 2 1/2 | 65 | Medium | 76.6 | 69.4 | 3.6 | 6.43 |
| insert! | 2 1/2 | 65 | Heavy | 76.6 | 67.6 | 4.5 | 7.93 |
| insert! | 3 | 80 | Light | 88.7 | 82.3 | 3.2 | 6.72 |
| insert! | 3 | 80 | Medium | 89.5 | 81.5 | 4.0 | 8.37 |
| insert! | 3 | 80 | Heavy | 89.5 | 79.5 | 5.0 | 10.30 |
| insert! | 4 | 100 | Light | 113.9 | 106.7 | 3.6 | 9.75 |
| insert! | 4 | 100 | Medium | 114.9 | 105.9 | 4.5 | 12.20 |
| insert! | 4 | 100 | Heavy | 114.9 | 104.1 | 5.4 | 14.50 |
| insert! | 5 | 125 | Medium | 140.6 | 130.6 | 5.0 | 16.60 |
| insert! | 5 | 125 | Heavy | 140.6 | 129.8 | 5.4 | 17.90 |
| insert! | 6 | 150 | Medium | 166.1 | 156.1 | 5.0 | 19.70 |
| insert! | 6 | 150 | Heavy | 166.1 | 155.3 | 5.4 | 21.30 |
| custom! | |||||||
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 22
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
