Sign in!
Home > Piping > Pipes and Tubes >
Welded and Seamless Stainless Steel Pipes
Standard Specification for General Requirements for Welded and Seamless Stainless Steel Pipes
welded seamless stainless steel pipe
Nominal DiameterScheduleOutside DiameterInside DiameterWall Thickness
inininin
insert!1/810S0.4050.3070.049
insert!1/840S0.4050.2690.068
insert!1/880S0.4050.2150.095
insert!1/410S0.5400.4100.065
insert!1/440S0.5400.3640.088
insert!1/480S0.5400.3020.119
insert!3/810S0.6750.5450.065
insert!3/840S0.6750.4930.091
insert!3/880S0.6750.4230.126
insert!1/25S0.8400.7100.065
insert!1/210S0.8400.6740.083
insert!1/240S0.8400.6220.109
insert!1/280S0.8400.5460.147
insert!3/45S1.0500.9200.065
insert!3/410S1.0500.8840.083
insert!3/440S1.0500.8240.113
insert!3/480S1.0500.7420.154
insert!15S1.3151.1850.065
insert!110S1.3151.0970.109
insert!140S1.3151.0490.133
insert!180S1.3150.9570.179
insert!1 1/45S1.6601.5300.065
insert!1 1/410S1.6601.4420.109
insert!1 1/440S1.6601.3800.140
insert!1 1/480S1.6601.2780.191
insert!1 1/25S1.9001.7700.065
insert!1 1/210S1.9001.6820.109
insert!1 1/240S1.9001.5920.154
insert!1 1/280S1.9001.4640.218
insert!25S2.3752.2450.065
insert!210S2.3752.1750.109
insert!240S2.3752.0670.154
insert!280S2.3751.9390.218
insert!2 1/25S2.8752.7090.083
insert!2 1/210S2.8752.6350.120
insert!2 1/240S2.8752.4690.203
insert!2 1/280S2.8752.3230.276
insert!35S3.5003.3340.083
insert!310S3.5003.2600.120
insert!340S3.5003.0680.216
insert!380S3.5002.9000.300
insert!3 1/25S4.0003.8340.083
insert!3 1/210S4.0003.7600.120
insert!3 1/240S4.0003.5480.226
insert!3 1/280S4.0003.3640.318
insert!45S4.5004.3340.083
insert!410S4.5004.2600.120
insert!440S4.5004.0260.237
insert!480S4.5003.8260.337
insert!55S5.5635.3450.109
insert!510S5.5635.2950.134
insert!540S5.5635.0030.280
insert!580S5.5634.6990.432
insert!65S6.6256.4070.109
insert!610S6.6256.3570.134
insert!640S6.6256.0650.280
insert!680S6.6255.7610.432
insert!85S8.6258.4070.109
insert!810S8.6258.3290.148
insert!840S8.6257.9810.322
insert!880S8.6257.6250.500
insert!105S10.75010.4820.134
insert!1010S10.75010.4200.165
insert!1010S10.75010.0200.365
insert!1040S10.7509.7500.500
insert!125S12.75012.4380.156
insert!1210S12.75012.3900.180
insert!1240S12.75012.0000.375
insert!1280S12.75011.0000.500
insert!145S14.00013.6880.156
insert!1410S14.00013.6240.188
insert!165S16.00015.6700.165
insert!1610S16.00015.6240.188
insert!185S18.00017.6700.165
insert!1810S18.00017.6240.188
insert!205S20.00019.6240.188
insert!2010S20.00019.5640.218
insert!225S22.00021.6240.188
insert!2210S22.00021.5640.218
insert!245S24.00023.5640.218
insert!2410S24.00023.5000.250
insert!305S30.00029.5000.250
insert!3010S30.00029.3760.312
custom!
inininin
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 9
