Dimensions for ANSI B16.9 Stainless Steel long radius 45 degrees elbows
| Nominal Diameter | Strength | Outside Diameter | Radius Center | Wall Thickness | |
| in | in | in | in | ||
| insert! | 3/4 | 5S | 1.050 | 1.125 | 0.066 |
| insert! | 3/4 | 10S | 1.050 | 1.125 | 0.083 |
| insert! | 3/4 | 40S | 0.750 | 1.050 | 0.113 |
| insert! | 3/4 | 80S | 0.750 | 1.050 | 0.154 |
| insert! | 3/4 | XXS | 0.750 | 1.050 | 0.308 |
| insert! | 1 | 5S | 1.315 | 1.5 | 0.065 |
| insert! | 1 | 10S | 1.315 | 1.5 | 0.109 |
| insert! | 1 | 40S | 1.315 | 1.5 | 0.133 |
| insert! | 1 | 80S | 1.315 | 1.5 | 0.179 |
| insert! | 1 | 160 | 1.315 | 1.5 | 0.250 |
| insert! | 1 | XXS | 1.315 | 1.5 | 0.358 |
| insert! | 1 1/4 | 5S | 1.660 | 1.875 | 0.065 |
| insert! | 1 1/4 | 10S | 1.660 | 1.875 | 0.109 |
| insert! | 1 1/4 | 40S | 1.660 | 1.875 | 0.140 |
| insert! | 1 1/4 | 80S | 1.660 | 1.875 | 0.191 |
| insert! | 1 1/4 | 160 | 1.660 | 1.875 | 0.250 |
| insert! | 1 1/4 | XXS | 1.660 | 1.875 | 0.382 |
| insert! | 1 1/2 | 5S | 1.900 | 2.250 | 0.065 |
| insert! | 1 1/2 | 10S | 1.900 | 2.250 | 0.109 |
| insert! | 1 1/2 | 40S | 1.900 | 2.250 | 0.145 |
| insert! | 1 1/2 | 80S | 1.900 | 2.250 | 0.200 |
| insert! | 1 1/2 | 160 | 1.900 | 2.250 | 0.281 |
| insert! | 1 1/2 | XXS | 1.900 | 2.250 | 0.400 |
| insert! | 2 | 5S | 2.375 | 3 | 0.065 |
| insert! | 2 | 10S | 2.375 | 3 | 0.109 |
| insert! | 2 | 40S | 2.375 | 3 | 0.154 |
| insert! | 2 | 80S | 2.375 | 3 | 0.218 |
| insert! | 2 | 160 | 2.375 | 3 | 0.343 |
| insert! | 2 | XXS | 2.375 | 3 | 0.436 |
| insert! | 2 1/2 | 5S | 2.875 | 3.750 | 0.083 |
| insert! | 2 1/2 | 10S | 2.875 | 3.750 | 0.120 |
| insert! | 2 1/2 | 40S | 2.875 | 3.750 | 0.203 |
| insert! | 2 1/2 | 80S | 2.875 | 3.750 | 0.276 |
| insert! | 2 1/2 | 80S | 2.875 | 3.750 | 0.375 |
| insert! | 2 1/2 | 160 | 2.875 | 3.750 | 0.375 |
| insert! | 2 1/2 | XXS | 2.875 | 3.750 | 0.552 |
| insert! | 3 | 5S | 3.500 | 4.5 | 0.083 |
| insert! | 3 | 10S | 3.500 | 4.5 | 0.120 |
| insert! | 3 | 40S | 3.500 | 4.5 | 0.216 |
| insert! | 3 | 80S | 3.500 | 4.5 | 0.300 |
| insert! | 3 | 160 | 3.500 | 4.5 | 0.438 |
| insert! | 3 | XXS | 3.500 | 4.5 | 0.600 |
| insert! | 3 1/2 | 5S | 4.000 | 5.250 | 0.083 |
| insert! | 3 1/2 | 10S | 4.000 | 5.250 | 0.120 |
| insert! | 3 1/2 | 40S | 4.000 | 5.250 | 0.226 |
| insert! | 3 1/2 | 40S | 4.000 | 5.250 | 0.318 |
| insert! | 3 1/2 | XXS | 4.000 | 5.250 | 0.636 |
| insert! | 4 | 5S | 4.500 | 6 | 0.083 |
| insert! | 4 | 10S | 4.500 | 6 | 0.120 |
| insert! | 4 | 40S | 4.500 | 6 | 0.237 |
| insert! | 4 | 80S | 4.500 | 6 | 0.337 |
| insert! | 4 | 160 | 4.500 | 6 | 0.531 |
| insert! | 4 | XXS | 4.500 | 6 | 0.674 |
| insert! | 5 | 5S | 5.563 | 7.5 | 0.109 |
| insert! | 5 | 10S | 5.563 | 7.5 | 0.134 |
| insert! | 5 | 40S | 5.563 | 7.5 | 0.258 |
| insert! | 5 | 80S | 5.563 | 7.5 | 0.375 |
| insert! | 5 | 160 | 5.563 | 7.5 | 0.625 |
| insert! | 5 | XXS | 5.563 | 7.5 | 0.750 |
| insert! | 6 | 5S | 6.625 | 9 | 0.109 |
| insert! | 6 | 10S | 6.625 | 9 | 0.134 |
| insert! | 6 | 40S | 6.625 | 9 | 0.280 |
| insert! | 6 | 80S | 6.625 | 9 | 0.432 |
| insert! | 6 | 160 | 6.625 | 9 | 0.718 |
| insert! | 6 | XXS | 6.625 | 9 | 0.864 |
| insert! | 8 | 5S | 8.625 | 12 | 0.109 |
| insert! | 8 | 10S | 8.625 | 12 | 0.148 |
| insert! | 8 | 40S | 8.625 | 12 | 0.322 |
| insert! | 8 | 80S | 8.625 | 12 | 0.500 |
| insert! | 8 | 160 | 8.625 | 12 | 0.875 |
| insert! | 8 | XXS | 8.625 | 12 | 0.906 |
| insert! | 10 | 5S | 10.750 | 15 | 0.134 |
| insert! | 10 | 10S | 10.750 | 15 | 0.165 |
| insert! | 10 | 40S | 10.750 | 15 | 0.365 |
| insert! | 10 | 80S | 10.750 | 15 | 0.500 |
| insert! | 10 | 160 | 10.750 | 15 | 1.125 |
| insert! | 12 | 5S | 12.750 | 18 | 0.156 |
| insert! | 12 | 10S | 12.750 | 18 | 0.180 |
| insert! | 12 | 40S | 12.750 | 18 | 0.375 |
| insert! | 12 | 80S | 12.750 | 18 | 0.500 |
| insert! | 12 | 160 | 12.750 | 18 | 1.312 |
| insert! | 14 | 5S | 14.000 | 21 | 0.156 |
| insert! | 14 | 10S | 14.000 | 21 | 0.188 |
| insert! | 14 | 40S | 14.000 | 21 | 0.375 |
| insert! | 14 | 80S | 14.000 | 21 | 0.500 |
| insert! | 16 | 5S | 16.000 | 24 | 0.165 |
| insert! | 16 | 10S | 16.000 | 24 | 0.188 |
| insert! | 16 | 40S | 16.000 | 24 | 0.375 |
| insert! | 16 | 80S | 16.000 | 24 | 0.500 |
| insert! | 18 | 5S | 18.000 | 27 | 0.165 |
| insert! | 18 | 10S | 18.000 | 27 | 0.188 |
| insert! | 18 | 40S | 18.000 | 27 | 0.375 |
| insert! | 18 | 80S | 18.000 | 27 | 0.500 |
| insert! | 20 | 5S | 20.000 | 30 | 0.188 |
| insert! | 20 | 10S | 20.000 | 30 | 0.218 |
| insert! | 20 | 40S | 20.000 | 30 | 0.375 |
| insert! | 20 | 80S | 20.000 | 30 | 0.500 |
| insert! | 22 | 5S | 22.000 | 33 | 0.188 |
| insert! | 22 | 10S | 22.000 | 33 | 0.218 |
| insert! | 22 | 40S | 22.000 | 33 | 0.375 |
| insert! | 22 | 80S | 22.000 | 33 | 0.500 |
| insert! | 24 | 5S | 24.000 | 36 | 0.218 |
| insert! | 24 | 10S | 24.000 | 36 | 0.250 |
| insert! | 24 | 40S | 24.000 | 36 | 0.375 |
| insert! | 24 | 80S | 24.000 | 36 | 0.500 |
| custom! | |||||
| in | in | in | in |
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 11
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
