Home > Structural and Bar Sections > Hollow Structural Sections >
Square Hollow Structural Sections - HSS
Square Hollow Strucural Sections - Imperial Units
square hollow strucural sections hss
Designation Width Depth Thickness Mass Area of Section Second Moment of Area
in in in lb/ft in**2 in**4
insert! 32x32x5/8 32 32 0.63 259.83 76.4 12300
insert! 32x32x1/2 32 32 0.5 210.72 61.9 10100
insert! 32x32x3/8 32 32 0.38 159.37 46.8 7750
insert! 30x30x5/8 30 30 0.63 242.82 71.4 10100
insert! 30x30x1/2 30 30 0.5 197.11 57.9 8320
insert! 30x30x3/8 30 30 0.38 149.16 43.8 6370
insert! 28x28x5/8 28 28 0.63 225.8 66.4 8140
insert! 28x28x1/2 28 28 0.5 183.5 53.9 6730
insert! 28x28x3/8 28 28 0.38 138.95 40.8 5150
insert! 26x26x5/8 26 26 0.63 208.79 61.4 6460
insert! 26x26x1/2 26 26 0.5 169.89 49.9 5350
insert! 26x26x3/8 26 26 0.38 128.74 37.8 4110
insert! 24x24x5/8 24 24 0.63 191.78 56.4 5030
insert! 24x24x1/2 24 24 0.5 156.28 45.9 4170
insert! 24x24x3/8 24 24 0.38 118.53 34.8 3210
insert! 22x22x5/8 22 22 0.63 174.76 51.4 3820
insert! 22x22x1/2 22 22 0.5 142.67 41.9 3190
insert! 22x22x3/8 22 22 0.38 108.32 31.8 2460
insert! 20x20x5/8 20 20 0.63 157.75 46.4 2830
insert! 20x20x1/2 20 20 0.5 129.06 37.9 2370
insert! 20x20x3/8 20 20 0.38 98.12 28.8 1830
insert! 18x18x5/8 18 18 0.63 140.73 41.4 2020
insert! 18x18x1/2 18 18 0.5 115.45 33.9 1700
insert! 18x18x3/8 18 18 0.38 87.91 25.8 1320
insert! 16x16x5/8 16 16 0.58 127.37 35 1370
insert! 16x16x1/2 16 16 0.47 103.3 28.3 1130
insert! 16x16x3/8 16 16 0.35 78.52 21.5 873
insert! 16x16x5/16 16 16 0.29 65.87 18.1 739
insert! 14x14x5/8 14 14 0.58 110.36 30.3 896
insert! 14x14x1/2 14 14 0.47 89.68 24.6 743
insert! 14x14x3/8 14 14 0.35 68.31 18.7 577
insert! 14x14x5/16 14 14 0.29 57.36 15.7 490
insert! 12x12x5/8 12 12 0.58 93.34 25.7 548
insert! 12x12x1/2 12 12 0.47 76.07 20.9 457
insert! 12x12x3/8 12 12 0.35 58.1 16 357
insert! 12x12x5/16 12 12 0.29 48.86 13.4 304
insert! 12x12x1/4 12 12 0.23 39.43 10.8 248
insert! 10x10x5/8 10 10 0.58 76.33 21 304
insert! 10x10x1/2 10 10 0.47 62.46 17.2 256
insert! 10x10x3/8 10 10 0.35 47.9 13.2 202
insert! 10x10x5/16 10 10 0.29 40.35 11.1 172
insert! 10x10x1/4 10 10 0.23 32.63 8.96 141
insert! 10x10x3/16 10 10 0.17 24.73 6.76 108
insert! 9x9x1/2 9 9 0.47 55.66 15.3 182
insert! 9x9x3/8 9 9 0.35 42.79 11.8 145
insert! 9x9x5/16 9 9 0.29 36.1 9.92 124
insert! 9x9x1/4 9 9 0.23 29.23 8.03 102
insert! 9x9x3/16 9 9 0.17 22.18 6.06 78.2
insert! 8x8x5/8 8 8 0.58 59.32 16.4 146
insert! 8x8x1/2 8 8 0.47 48.85 13.5 125
insert! 8x8x3/8 8 8 0.35 37.69 10.4 99.6
insert! 8x8x5/16 8 8 0.29 31.84 8.76 85.6
insert! 8x8x1/4 8 8 0.23 25.82 7.1 70.7
insert! 8x8x3/16 8 8 0.17 19.63 5.37 54.4
insert! 7x7x5/8 7 7 0.58 50.81 14 93.3
insert! 7x7x1/2 7 7 0.47 42.05 11.6 80.5
insert! 7x7x3/8 7 7 0.35 32.58 8.97 64.9
insert! 7x7x5/16 7 7 0.29 27.59 7.59 56.1
insert! 7x7x1/4 7 7 0.23 22.42 6.17 46.5
insert! 7x7x3/16 7 7 0.17 17.08 4.67 36
insert! 6x6x5/8 6 6 0.58 42.3 11.7 55.1
insert! 6x6x1/2 6 6 0.47 35.24 9.74 48.2
insert! 6x6x3/8 6 6 0.35 27.48 7.58 39.4
insert! 6x6x5/16 6 6 0.29 23.34 6.43 34.3
insert! 6x6x1/4 6 6 0.23 19.02 5.24 28.6
insert! 6x6x3/16 6 6 0.17 14.53 3.98 22.3
insert! 6x6x1/8 6 6 0.12 9.86 2.7 15.5
insert! 5-1/2x5-1/2x3/8 5.5 5.5 0.35 24.93 6.88 29.7
insert! 5-1/2x5-1/2x5/16 5.5 5.5 0.29 21.21 5.85 25.9
insert! 5-1/2x5-1/2x1/4 5.5 5.5 0.23 17.32 4.77 21.7
insert! 5-1/2x5-1/2x3/16 5.5 5.5 0.17 13.25 3.63 17
insert! 5-1/2x5-1/2x1/8 5.5 5.5 0.12 9.01 2.46 11.8
insert! 5x5x1/2 5 5 0.47 28.43 7.88 26
insert! 5x5x3/8 5 5 0.35 22.37 6.18 21.7
insert! 5x5x5/16 5 5 0.29 19.08 5.26 19
insert! 5x5x1/4 5 5 0.23 15.62 4.3 16
insert! 5x5x3/16 5 5 0.17 11.97 3.28 12.6
insert! 5x5x1/8 5 5 0.12 8.16 2.23 8.8
insert! 4-1/2x4-1/2x1/2 4.5 4.5 0.47 25.03 6.95 18
insert! 4-1/2x4-1/2x3/8 4.5 4.5 0.35 19.82 5.48 15.3
insert! 4-1/2x4-1/2x5/16 4.5 4.5 0.29 16.96 4.68 13.5
insert! 4-1/2x4-1/2x1/4 4.5 4.5 0.23 13.91 3.84 11.4
insert! 4-1/2x4-1/2x3/16 4.5 4.5 0.17 10.7 2.93 9.02
insert! 4-1/2x4-1/2x1/8 4.5 4.5 0.12 7.31 2 6.35
insert! 4x4x1/2 4 4 0.47 21.63 6.02 11.9
insert! 4x4x3/8 4 4 0.35 17.27 4.78 10.3
insert! 4x4x5/16 4 4 0.29 14.83 4.1 9.14
insert! 4x4x1/4 4 4 0.23 12.21 3.37 7.8
insert! 4x4x3/16 4 4 0.17 9.42 2.58 6.21
insert! 4x4x1/8 4 4 0.12 6.46 1.77 4.4
insert! 3-1/2x3-1/2x3/8 3.5 3.5 0.35 14.72 4.09 6.48
insert! 3-1/2x3-1/2x5/16 3.5 3.5 0.29 12.7 3.52 5.84
insert! 3-1/2x3-1/2x1/4 3.5 3.5 0.23 10.51 2.91 5.04
insert! 3-1/2x3-1/2x3/16 3.5 3.5 0.17 8.15 2.24 4.05
insert! 3-1/2x3-1/2x1/8 3.5 3.5 0.12 5.61 1.54 2.9
insert! 3x3x3/8 3 3 0.35 12.17 3.39 3.77
insert! 3x3x5/16 3 3 0.29 10.58 2.94 3.45
insert! 3x3x1/4 3 3 0.23 8.81 2.44 3.02
insert! 3x3x3/16 3 3 0.17 6.87 1.89 2.46
insert! 3x3x1/8 3 3 0.12 4.75 1.3 1.78
insert! 2-1/2x2-1/2x5/16 2.5 2.5 0.29 8.45 2.35 1.82
insert! 2-1/2x2-1/2x1/4 2.5 2.5 0.23 7.11 1.97 1.63
insert! 2-1/2x2-1/2x3/16 2.5 2.5 0.17 5.59 1.54 1.35
insert! 2-1/2x2-1/2x1/8 2.5 2.5 0.12 3.9 1.07 1
insert! 2-1/4x2-1/4x1/4 2.25 2.25 0.23 6.26 1.74 1.13
insert! 2-1/4x2-1/4x3/16 2.25 2.25 0.17 4.96 1.37 0.95
insert! 2-1/4x2-1/4x1/8 2.25 2.25 0.12 3.48 0.96 0.71
insert! 2x2x1/4 2 2 0.23 5.41 1.51 0.75
insert! 2x2x3/16 2 2 0.17 4.32 1.19 0.64
insert! 2x2x1/8 2 2 0.12 3.05 0.84 0.49
insert! 1-3/4x1-3/4x3/16 1.75 1.75 0.17 3.68 1.02 0.41
insert! 1-5/8x1-5/8x3/16 1.625 1.625 0.17 3.36 0.93 0.31
insert! 1-5/8x1-5/8x1/8 1.625 1.625 0.12 2.42 0.67 0.25
insert! 1-1/2x1-1/2x3/16 1.5 1.5 0.17 3.04 0.84 0.24
insert! 1-1/2x1-1/2x1/8 1.5 1.5 0.12 2.2 0.61 0.19
insert! 1-1/4x1-1/4x3/16 1.25 1.25 0.17 2.4 0.67 0.12
insert! 1-1/4x1-1/4x1/8 1.25 1.25 0.12 1.78 0.49 0.1
custom!
Note that rounded corners are not drawn. It makes moving and positioning of the components easier.
NOTE!! The ""insert!" and the Tools features works only from the engineeringtoolbox plug-in inside of SketchUp. Add and edit parametric objects to the SketchUp model!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
