Home
HVAC
Duct Work - Elbows
Spiral pipe elbows - metric units
Insert elbows to your Sketchup model by clicking the "insert!" links.
Add custom bends by modifying parameters in the "custom" row.
Nominal Diameter | Outside Diameter | Radius Center | Wall Thickness | |
mm | mm | mm | mm | |
insert! | 60 | 63 | 63 | 1 |
insert! | 80 | 80 | 80 | 1 |
insert! | 100 | 100 | 100 | 1 |
insert! | 125 | 125 | 125 | 1 |
insert! | 160 | 160 | 160 | 1 |
insert! | 200 | 200 | 200 | 1 |
insert! | 250 | 250 | 250 | 1 |
insert! | 315 | 315 | 315 | 1 |
insert! | 400 | 400 | 400 | 1 |
insert! | 500 | 500 | 500 | 1 |
insert! | 630 | 630 | 630 | 1 |
insert! | 800 | 800 | 800 | 1 |
insert! | 1000 | 1000 | 1000 | 1 |
insert! | 1250 | 1250 | 1250 | 1 |
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
