Spiral pipe elbows - imperial units
Insert elbows to your Sketchup model by clicking the "insert!" links.
Add custom bends by modifying parameters in the "custom" row.
| Nominal Diameter | Outside Diameter | Radius Center | Wall Thickness | |
| in | in | in | in | |
| insert! | 3 | 3 | 4.5 | 0.0276 |
| insert! | 4 | 4 | 6 | 0.0276 |
| insert! | 5 | 5 | 7.5 | 0.0276 |
| insert! | 6 | 6 | 9 | 0.0276 |
| insert! | 8 | 8 | 12 | 0.0276 |
| insert! | 9 | 9 | 13.5 | 0.0276 |
| insert! | 10 | 10 | 15 | 0.0276 |
| insert! | 11 | 11 | 16.5 | 0.0276 |
| insert! | 12 | 12 | 18 | 0.0276 |
| insert! | 13 | 13 | 19.5 | 0.0276 |
| insert! | 14 | 14 | 21 | 0.0276 |
| insert! | 15 | 15 | 22.5 | 0.0276 |
| insert! | 16 | 16 | 24 | 0.0276 |
| insert! | 17 | 17 | 25.5 | 0.0276 |
| insert! | 18 | 18 | 27 | 0.0276 |
| insert! | 20 | 20 | 30 | 0.0276 |
| insert! | 22 | 22 | 33 | 0.0336 |
| insert! | 24 | 24 | 36 | 0.0336 |
| insert! | 26 | 26 | 39 | 0.0336 |
| insert! | 28 | 28 | 42 | 0.0336 |
| insert! | 30 | 30 | 45 | 0.0336 |
| insert! | 32 | 32 | 48 | 0.0336 |
| insert! | 34 | 34 | 51 | 0.0336 |
| insert! | 36 | 36 | 54 | 0.0336 |
| insert! | 38 | 38 | 57 | 0.0396 |
| insert! | 40 | 40 | 60 | 0.0396 |
| insert! | 42 | 42 | 63 | 0.0396 |
| insert! | 44 | 44 | 66 | 0.0396 |
| insert! | 46 | 46 | 69 | 0.0396 |
| insert! | 48 | 48 | 72 | 0.0396 |
| insert! | 50 | 50 | 75 | 0.0516 |
| insert! | 52 | 52 | 78 | 0.0516 |
| insert! | 54 | 54 | 81 | 0.0516 |
| insert! | 56 | 56 | 84 | 0.0516 |
| insert! | 58 | 58 | 87 | 0.0516 |
| insert! | 60 | 60 | 90 | 0.0516 |
| insert! | 64 | 64 | 96 | 0.0516 |
| insert! | 66 | 66 | 99 | 0.0516 |
| insert! | 68 | 68 | 102 | 0.0516 |
| insert! | 70 | 70 | 105 | 0.0516 |
| insert! | 72 | 72 | 108 | 0.0516 |
| custom! | ||||
| in | in | in | in |
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
