Sign in!
Home > Lumber >
Softwood Dimensional Lumber
Softwood Dimensional Lumber and Timber Sizes - Metric Units
lumber
Nominal DimensionWidthDepth
mmmm
insert!36 x 14836148
insert!48 x 14848148
insert!36 x 19836198
insert!48 x 19848198
insert!73 x 19873198
insert!36 x 22336223
insert!48 x 22348223
insert!73 x 22378223
custom!
mmmm
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 9
