Sign in!
Home > Piping > Crosses >
ASME B-16.9 Butt Welded Reducing Outlet Crosses
Reducing outlet crosses
crosses
Note! Outside diameters and dimensions are correct for all schedules. Thickness are based on standard schedules. Use custom insert at the end of the table to insert custom components with other schedules.
If internal details are important for your application - modify the component after inserted by selecting the internal faces, right clicking, and using the Intersecting tool - remove all unwanted faces and lines.
Nominal DiameterRun DiameterRunRun ThicknessOutlet DiameterOutletOutlet Thickness
ininininininin
insert!1/2 x 1/2 x 1/40.8401.000.1090.6801.000.109
insert!1/2 x 1/2 x 3/80.8401.000.1090.541.000.109
insert!3/4 x 3/4 x 3/81.0501.120.1130.841.120.109
insert!3/4 x 3/4 x 1/21.0101.120.1130.681.120.109
insert!1 x 1 x 3/41.3151.500.1331.051.500.113
insert!1 x 1 x 1/21.3151.500.1330.841.500.109
insert!1 1/4 x 1 1/4 x 11.661.880.1401.321.880.133
insert!1 1/4 x 1 1/4 x 3/41.661.880.1401.051.880.113
insert!1 1/4 x 1 1/4 x 1/21.661.880.1400.841.880.109
insert!1 1/2 x 1 1/2 x 1 1/41.902.250.1451.662.250.140
insert!1 1/2 x 1 1/2 x 11.902.250.1451.322.250.133
insert!1 1/2 x 1 1/2 x 3/41.902.250.1451.052.250.113
insert!1 1/2 x 1 1/2 x 1/21.902.250.1450.842.250.109
insert!2 x 2 x 1 1/22.3752.500.1541.902.380.145
insert!2 x 2 x 1 1/42.3752.500.1541.662.250.140
insert!2 x 2 x 12.3752.500.1541.322.000.133
insert!2 x 2 x 3/42.3752.500.1541.051.750.113
insert!2 1/2 x 2 1/2 x 22.8753.000.2032.382.750.154
insert!2 1/2 x 2 1/2 x 1 1/22.8753.000.2031.902.620.145
insert!2 1/2 x 2 1/2 x 1 1/42.8753.000.2031.662.500.140
insert!2 1/2 x 2 1/2 x 12.8753.000.2031.322.250.133
insert!3 x 3 x 2 1/23.503.380.2162.883.250.203
insert!3 x 3 x 23.503.380.2162.383.000.154
insert!3 x 3 x 1 1/23.503.380.2161.902.880.145
insert!3 x 3 x 1 1/43.503.380.2161.662.750.140
insert!3 1/2 x 3 1/2 x 34.003.750.2263.503.620.216
insert!3 1/2 x 3 1/2 x 2 1/24.003.750.2262.883.500.203
insert!3 1/2 x 3 1/2 x 24.003.750.2262.383.250.154
insert!3 1/2 x 3 1/2 x 1 1/24.003.750.2261.903.120.145
insert!4 x 4 x 3 1/24.504.120.2374.004.000.226
insert!4 x 4 x 34.504.120.2373.503.880.216
insert!4 x 4 x 2 1/24.504.120.2372.883.750.203
insert!4 x 4 x 24.504.120.2372.383.500.154
insert!4 x 4 x 1 1/24.504.120.2371.903.380.145
insert!5 x 5 x 45.5634.880.2584.504.620.237
insert!5 x 5 x 3 1/25.5634.880.2584.004.500.226
insert!5 x 5 x 35.5634.880.2583.504.380.216
insert!5 x 5 x 2 1/25.5634.880.2582.884.250.203
insert!5 x 5 x 25.5634.880.2582.384.120.154
insert!6 x 6 x 56.6255.620.2805.565.380.258
insert!6 x 6 x 46.6255.620.2804.505.120.237
insert!6 x 6 x 3 1/26.6255.620.2804.005.000.226
insert!6 x 6 x 36.6255.620.2803.504.880.216
insert!6 x 6 x 2 1/26.6255.620.2802.884.750.203
insert!8 x 8 x 68.6257.000.3226.626.620.280
insert!8 x 8 x 58.6257.000.3225.566.380.258
insert!8 x 8 x 48.6257.000.3224.506.120.237
insert!8 x 8 x 3 1/28.6257.000.3224.006.000.226
insert!10 x 10 x 810.758.500.3658.628.000.322
insert!10 x 10 x 610.758.500.3656.627.620.280
insert!10 x 10 x 510.758.500.3655.567.500.258
insert!10 x 10 x 410.758.500.3654.507.250.237
insert!12 x 12 x 1012.7510.000.37510.759.500.365
insert!12 x 12 x 812.7510.000.3758.629.000.322
insert!12 x 12 x 612.7510.000.3756.628.620.280
insert!12 x 12 x 512.7510.000.3755.568.500.258
insert!14 x 14 x 1214.0011.000.37512.7510.620.375
insert!14 x 14 x 1014.0011.000.37510.7510.120.365
insert!14 x 14 x 814.0011.000.3758.629.750.322
insert!14 x 14 x 614.0011.000.3756.629.380.280
insert!16 x 16 x 1416.0012.000.37514.0012.000.375
insert!16 x 16 x 1216.0012.000.37512.7511.620.375
insert!16 x 16 x 1016.0012.000.37510.7511.120.365
insert!16 x 16 x 816.0012.000.3758.6210.750.322
insert!16 x 16 x 616.0012.000.3756.6210.380.280
insert!18 x 18 x 1618.0013.500.37516.0013.000.375
insert!18 x 18 x 1418.0013.500.37514.0013.000.375
insert!18 x 18 x 1218.0013.500.37512.7512.620.375
insert!18 x 18 x 1018.0013.500.37510.7512.120.365
insert!18 x 18 x 818.0013.500.3758.6211.750.322
insert!20 x 20 x 1820.0015.000.37518.0014.500.375
insert!20 x 20 x 1620.0015.000.37516.0014.000.375
insert!20 x 20 x 1420.0015.000.37514.0014.000.375
insert!20 x 20 x 1220.0015.000.37512.7513.620.375
insert!20 x 20 x 1020.0015.000.37510.7513.120.365
insert!20 x 20 x 820.0015.000.3758.6212.750.322
insert!22 x 22 x 2022.0016.500.37520.0016.000.375
insert!22 x 22 x 1822.0016.500.37518.0015.500.375
insert!22 x 22 x 1622.0016.500.37516.0015.000.375
insert!22 x 22 x 1422.0016.500.37514.0015.000.375
insert!22 x 22 x 1222.0016.500.37512.7514.6250.375
insert!22 x 22 x 1022.0016.500.37510.7514.1250.365
insert!24 x 24 x 2224.0017.000.37522.0017.000.375
insert!24 x 24 x 2024.0017.000.37520.0017.000.375
insert!24 x 24 x 1824.0017.000.37518.0016.500.375
insert!24 x 24 x 1624.0017.000.37516.0016.000.375
insert!24 x 24 x 1424.0017.000.37514.0016.000.375
insert!24 x 24 x 1224.0017.000.37512.7515.6250.375
insert!24 x 24 x 1024.0017.000.37510.7515.1250.365
insert!26 x 26 x 2426.0019.500.37524.0019.000.375
insert!26 x 26 x 2226.0019.500.37522.0018.500.375
insert!26 x 26 x 2026.0019.500.37520.0018.000.375
insert!26 x 26 x 1826.0019.500.37518.0017.500.375
insert!26 x 26 x 1626.0019.500.37516.0017.000.375
insert!26 x 26 x 1426.0019.500.37514.0017.000.375
insert!26 x 26 x 1226.0019.500.37512.7516.6250.375
insert!28 x 28 x 2628.0020.500.37526.0020.500.375
insert!28 x 28 x 2428.0020.500.37524.0020.000.375
insert!28 x 28 x 2228.0020.500.37522.0019.500.375
insert!28 x 28 x 2028.0020.500.37520.0019.000.375
insert!28 x 28 x 1828.0020.500.37518.0018.500.375
insert!28 x 28 x 1628.0020.500.37516.0018.000.375
insert!28 x 28 x 1428.0020.500.37514.0018.000.375
insert!28 x 28 x 1228.0020.500.37512.7517.6250.375
insert!30 x 30 x 2830.0022.000.37528.0021.500.375
insert!30 x 30 x 2630.0022.000.37526.0021.500.375
insert!30 x 30 x 2430.0022.000.37524.0021.000.375
insert!30 x 30 x 2230.0022.000.37522.0020.500.375
insert!30 x 30 x 2030.0022.000.37520.0020.000.375
insert!30 x 30 x 1830.0022.000.37518.0019.500.375
insert!30 x 30 x 1630.0022.000.37516.0019.000.375
insert!30 x 30 x 1430.0022.000.37514.0019.000.375
insert!30 x 30 x 1230.0022.000.37512.7518.6250.375
insert!30 x 30 x 1030.0022.000.37510.7518.1250.375
insert!32 x 32 x 3032.0023.500.37530.0023.000.375
insert!32 x 32 x 2832.0023.500.37528.0022.500.375
insert!32 x 32 x 2632.0023.500.37526.0022.500.375
insert!32 x 32 x 2432.0023.500.37524.0022.000.375
insert!32 x 32 x 2232.0023.500.37522.0021.500.375
insert!32 x 32 x 2032.0023.500.37520.0021.000.375
insert!32 x 32 x 1832.0023.500.37518.0020.500.375
insert!32 x 32 x 1632.0023.500.37516.0020.000.375
insert!32 x 32 x 1432.0023.500.37514.0020.000.375
insert!34 x 34 x 3234.0025.000.37532.0024.500.375
insert!34 x 34 x 3034.0025.000.37530.0024.000.375
insert!34 x 34 x 2834.0025.000.37528.0023.500.375
insert!34 x 34 x 2634.0025.000.37526.0023.500.375
insert!34 x 34 x 2434.0025.000.37524.0023.000.375
insert!34 x 34 x 2234.0025.000.37522.0022.500.375
insert!34 x 34 x 2034.0025.000.37520.0022.000.375
insert!34 x 34 x 1834.0025.000.37518.0021.500.375
insert!34 x 34 x 1634.0025.000.37516.0021.000.375
insert!36 x 36 x 3436.0026.500.37534.0026.000.375
insert!36 x 36 x 3236.0026.500.37532.0025.500.375
insert!36 x 36 x 3036.0026.500.37530.0025.000.375
insert!36 x 36 x 2836.0026.500.37528.0024.500.375
insert!36 x 36 x 2636.0026.500.37526.0024.500.375
insert!36 x 36 x 2436.0026.500.37524.0024.000.375
insert!36 x 36 x 2236.0026.500.37522.0023.500.375
insert!36 x 36 x 2036.0026.500.37520.0023.500.375
insert!36 x 36 x 1836.0026.500.37518.0022.500.375
insert!36 x 36 x 1636.0026.500.37516.0022.000.375
insert!38 x 38 x 3638.0028.000.37536.0028.000.375
insert!38 x 38 x 3438.0028.000.37534.0027.500.375
insert!38 x 38 x 3238.0028.000.37532.0027.000.375
insert!38 x 38 x 3038.0028.000.37530.0026.500.375
insert!38 x 38 x 2838.0028.000.37528.0025.500.375
insert!38 x 38 x 2638.0028.000.37526.0025.500.375
insert!38 x 38 x 2438.0028.000.37524.0025.000.375
insert!38 x 38 x 2238.0028.000.37522.0024.500.375
insert!38 x 38 x 2038.0028.000.37520.0024.000.375
insert!38 x 38 x 1838.0028.000.37518.0023.500.375
insert!40 x 40 x 3840.0029.500.37538.0029.500.375
insert!40 x 40 x 3640.0029.500.37536.0029.000.375
insert!40 x 40 x 3440.0029.500.37534.0028.500.375
insert!40 x 40 x 3240.0029.500.37532.0028.000.375
insert!40 x 40 x 3040.0029.500.37530.0027.500.375
insert!40 x 40 x 2840.0029.500.37528.0026.500.375
insert!40 x 40 x 2640.0029.500.37526.0026.500.375
insert!40 x 40 x 2440.0029.500.37524.0026.000.375
insert!40 x 40 x 2240.0029.500.37522.0025.500.375
insert!40 x 40 x 2040.0029.500.37520.0025.000.375
insert!40 x 40 x 1840.0029.500.37518.0024.500.375
insert!42 x 42 x 4042.0030.000.37540.0028.000.375
insert!42 x 42 x 3842.0030.000.37538.0028.000.375
insert!42 x 42 x 3642.0030.000.37536.0028.000.375
insert!42 x 42 x 3442.0030.000.37534.0028.000.375
insert!42 x 42 x 3242.0030.000.37532.0028.000.375
insert!42 x 42 x 3042.0030.000.37530.0028.000.375
insert!42 x 42 x 2842.0030.000.37528.0027.500.375
insert!42 x 42 x 2642.0030.000.37526.0027.500.375
insert!42 x 42 x 2442.0030.000.37524.0026.000.375
insert!42 x 42 x 2242.0030.000.37522.0026.000.375
insert!42 x 42 x 2042.0030.000.37520.0026.000.375
insert!42 x 42 x 1842.0030.000.37518.0025.500.375
insert!42 x 42 x 1642.0030.000.37516.0025.000.375
insert!44 x 44 x 4244.0032.000.37542.0030.000.375
insert!44 x 44 x 4044.0032.000.37540.0029.500.375
insert!44 x 44 x 3844.0032.000.37538.0029.000.375
insert!44 x 44 x 3644.0032.000.37536.0028.500.375
insert!44 x 44 x 3444.0032.000.37534.0028.500.375
insert!44 x 44 x 3244.0032.000.37532.0028.000.375
insert!44 x 44 x 3044.0032.000.37530.0028.000.375
insert!44 x 44 x 2844.0032.000.37528.0027.500.375
insert!44 x 44 x 2644.0032.000.37526.0027.500.375
insert!44 x 44 x 2444.0032.000.37524.0027.500.375
insert!44 x 44 x 2244.0032.000.37522.0027.000.375
insert!44 x 44 x 2044.0032.000.37520.0027.000.375
insert!46 x 46 x 4446.0033.500.37544.0031.500.375
insert!46 x 46 x 4246.0033.500.37542.0031.000.375
insert!46 x 46 x 4046.0033.500.37540.0030.500.375
insert!46 x 46 x 3846.0033.500.37538.0030.000.375
insert!46 x 46 x 3646.0033.500.37536.0030.000.375
insert!46 x 46 x 3446.0033.500.37534.0029.500.375
insert!46 x 46 x 3246.0033.500.37532.0029.500.375
insert!46 x 46 x 3046.0033.500.37530.0029.000.375
insert!46 x 46 x 2846.0033.500.37528.0029.000.375
insert!46 x 46 x 2646.0033.500.37526.0029.000.375
insert!46 x 46 x 2446.0033.500.37524.0028.500.375
insert!46 x 46 x 2246.0033.500.37522.0028.500.375
insert!48 x 48 x 4648.0035.000.37546.0033.000.375
insert!48 x 48 x 4448.0035.000.37544.0033.000.375
insert!48 x 48 x 4248.0035.000.37542.0032.000.375
insert!48 x 48 x 4048.0035.000.37540.0032.000.375
insert!48 x 48 x 3848.0035.000.37538.0032.000.375
insert!48 x 48 x 3648.0035.000.37536.0031.000.375
insert!48 x 48 x 3448.0035.000.37534.0031.000.375
insert!48 x 48 x 3248.0035.000.37532.0031.000.375
insert!48 x 48 x 3048.0035.000.37530.0030.000.375
insert!48 x 48 x 2848.0035.000.37528.0030.000.375
insert!48 x 48 x 2648.0035.000.37526.0030.000.375
insert!48 x 48 x 2448.0035.000.37524.0029.000.375
insert!48 x 48 x 2248.0035.000.37522.0029.000.375
custom!
ininininininin
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
