Standard Specification for General Requirements for Red Brass Tubes
| Nominal Diameter | Alternative Identification | Outside Diameter | Inside Diameter | Wall Thickness | Weight | Allowable Working Pressure at 100 - 200 degF | Allowable Working Pressure at 400 degF | |
| in | in | in | in | lb/ft | psi | psi | ||
| insert! | 1/8 | STD | 0.405 | 0.281 | 0.062 | 0.253 | 370 | 140 |
| insert! | 1/8 | XS | 0.405 | 0.205 | 0.100 | 0.363 | 1960 | 740 |
| insert! | 1/4 | STD | 0.540 | 0.376 | 0.082 | 0.447 | 870 | 330 |
| insert! | 1/4 | XS | 0.540 | 0.294 | 0.123 | 0.611 | 2210 | 830 |
| insert! | 3/8 | STD | 0.675 | 0.495 | 0.09 | 0.627 | 890 | 340 |
| insert! | 3/8 | XS | 0.675 | 0.421 | 0.127 | 0.829 | 1840 | 690 |
| insert! | 1/2 | STD | 0.840 | 0.626 | 0.107 | 0.934 | 900 | 340 |
| insert! | 1/2 | XS | 0.840 | 0.542 | 0.149 | 1.23 | 1740 | 660 |
| insert! | 3/4 | STD | 1.050 | 0.822 | 0.114 | 1.27 | 810 | 310 |
| insert! | 3/4 | XS | 1.050 | 0.736 | 0.157 | 1.67 | 1510 | 570 |
| insert! | 1 | STD | 1.315 | 1.063 | 0.126 | 1.78 | 630 | 240 |
| insert! | 1 | XS | 1.315 | 0.951 | 0.182 | 2.46 | 1340 | 510 |
| insert! | 1 1/4 | STD | 1.660 | 1.368 | 0.146 | 2.63 | 690 | 260 |
| insert! | 1 1/4 | XS | 1.660 | 1.272 | 0.194 | 3.39 | 1160 | 440 |
| insert! | 1 1/2 | STD | 1.900 | 1.600 | 0.150 | 3.13 | 640 | 240 |
| insert! | 1 1/2 | XS | 1.900 | 1.494 | 0.203 | 4.10 | 1090 | 410 |
| insert! | 2 | STD | 2.375 | 2.063 | 0.156 | 4.12 | 540 | 210 |
| insert! | 2 | XS | 2.375 | 1.933 | 0.221 | 5.67 | 1000 | 380 |
| insert! | 2 1/2 | STD | 2.875 | 2.501 | 0.187 | 5.99 | 450 | 170 |
| insert! | 2 1/2 | XS | 2.875 | 2.315 | 0.280 | 8.66 | 970 | 370 |
| insert! | 3 | STD | 3.500 | 3.062 | 0.219 | 8.56 | 510 | 190 |
| insert! | 3 | XS | 3.500 | 2.892 | 0.304 | 11.6 | 910 | 340 |
| insert! | 3 1/2 | STD | 4.000 | 3.500 | 0.250 | 11.2 | 570 | 220 |
| insert! | 3 1/2 | XS | 4.000 | 3.358 | 0.321 | 14.1 | 860 | 330 |
| insert! | 4 | STD | 4.500 | 4.000 | 0.250 | 12.7 | 510 | 190 |
| insert! | 4 | XS | 4.500 | 3.818 | 0.341 | 16.9 | 830 | 320 |
| insert! | 5 | STD | 5.563 | 5.062 | 0.251 | 15.8 | 410 | 160 |
| insert! | 5 | XS | 5.563 | 4.812 | 0.376 | 23.2 | 770 | 290 |
| insert! | 6 | STD | 6.625 | 6.125 | 0.250 | 19.0 | 340 | 130 |
| insert! | 6 | XS | 6.625 | 5.751 | 0.437 | 32.2 | 800 | 300 |
| insert! | 8 | STD | 8.625 | 8.001 | 0.312 | 30.9 | 360 | 140 |
| insert! | 8 | XS | 8.625 | 7.625 | 0.500 | 48.4 | 710 | 270 |
| insert! | 10 | STD | 10.750 | 10.020 | 0.365 | 45.2 | 360 | 140 |
| insert! | 10 | XS | 10.750 | 9.750 | 0.500 | 61.1 | 550 | 210 |
| insert! | 12 | STD | 12.750 | 12.000 | 0.375 | 55.3 | 320 | 120 |
| custom! | ||||||||
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 8
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
