Home
Function Curves
Curve based on the quation of a rectangular hyperbola
A Rectangular Hyperbola Function can be expressed as
y = a / x
Add a hyperbola function curve to your Sketchup model with the tool below!
Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
