Reload this page!
Home  > HVAC  > Duct Work - Piping  >
Rectangular Air Ducts - Metric Units
Commonly used rectangular ducts
rectangular air ducts
Add rectangular ducts to your Sketchup model by clicking "insert!"
Customized ducts can be added by modifying the "custom!" row.
Designation Width Depth Thickness
mm mm mm
insert! 200 x 100 200 100 0.5
insert! 200 x 150 200 150 0.5
insert! 300 x 100 300 100 0.5
insert! 300 x 150 300 150 0.5
insert! 300 x 200 300 200 0.5
insert! 400 x 100 400 100 0.5
insert! 400 x 150 400 150 0.5
insert! 400 x 200 400 200 0.5
insert! 500 x 150 500 150 0.5
insert! 500 x 200 500 200 0.5
insert! 500 x 300 500 300 0.5
insert! 500 x 400 500 400 0.5
insert! 600 x 150 600 150 0.5
insert! 600 x 200 600 200 0.5
insert! 600 x 300 600 300 0.5
insert! 600 x 400 600 400 0.5
insert! 600 x 500 600 500 0.5
insert! 800 x 200 800 200 0.5
insert! 800 x 300 800 300 0.5
insert! 800 x 400 800 400 0.5
insert! 800 x 500 800 500 0.5
insert! 800 x 600 800 600 0.5
insert! 1000 x 300 1000 300 0.5
insert! 1000 x 400 1000 400 0.5
insert! 1000 x 500 1000 500 0.5
insert! 1000 x 600 1000 600 0.5
insert! 1000 x 800 1000 800 0.5
custom!
Change before insert!
Tools - accessed from within Sketchup
Edit
undo!   redo!
Color
  change color!
View
iso!   top!   front!   right!   left!   back!   bottom!
Make Component
make!
Rotate Object(s)
around red!  , green!   or blue!   axis.
Move or Copy Object(s)
move/copy!
Knife
insert the Knife!   cut!
Move an Object to an other Objects Position
move!
Insert (Reference) Line
  startpoint
  endpoint         insert!
Insert Horizontal Plane
     insert!
Insert Vertical Plane
     insert!
     insert!
Insert Box
     insert!
