Home
HVAC
Duct Work - Piping
Commonly used rectangular ducts
Add rectangular ducts to your Sketchup model by clicking "insert!"
Customized ducts can be added by modifying the "custom!" row.
Designation | Width | Depth | Thickness | |
in | in | in | ||
insert! | 3 x 7 | 3 | 7 | 0.02 |
insert! | 4 x 5 | 4 | 5 | 0.02 |
insert! | 4 x 7 | 4 | 7 | 0.02 |
insert! | 4 x 9 | 4 | 9 | 0.02 |
insert! | 5 x 6 | 5 | 6 | 0.02 |
insert! | 5 x 7 | 5 | 7 | 0.02 |
insert! | 5 x 12 | 5 | 12 | 0.02 |
insert! | 6 x 6 | 6 | 6 | 0.02 |
insert! | 6 x 7 | 6 | 7 | 0.02 |
insert! | 6 x 10 | 6 | 10 | 0.02 |
insert! | 7 x 8 | 7 | 8 | 0.02 |
insert! | 7 x 10 | 7 | 10 | 0.02 |
insert! | 8 x 9 | 8 | 9 | 0.02 |
insert! | 8 x 12 | 8 | 12 | 0.02 |
insert! | 8 x 14 | 8 | 14 | 0.02 |
insert! | 8 x 15 | 8 | 15 | 0.02 |
insert! | 9 x 9 | 9 | 9 | 0.02 |
insert! | 9 x 12 | 9 | 12 | 0.02 |
insert! | 10 x 10 | 10 | 10 | 0.02 |
insert! | 10 x 12 | 10 | 12 | 0.02 |
insert! | 10 x 14 | 10 | 14 | 0.02 |
insert! | 12 x 12 | 12 | 12 | 0.02 |
insert! | 12 x 14 | 12 | 14 | 0.02 |
insert! | 14 x 14 | 14 | 14 | 0.02 |
insert! | 14 x 16 | 14 | 16 | 0.02 |
insert! | 14 x 20 | 14 | 20 | 0.02 |
insert! | 16 x 20 | 16 | 20 | 0.02 |
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
