Square edged plywood boards - Metric Units
Nominal Dimension | Length | Width | Thickness | |
mm | mm | mm | ||
insert! | 2440 x 1220 x 6 | 2440 | 1220 | 6 |
insert! | 2440 x 1220 x 8 | 2440 | 1220 | 8 |
insert! | 2440 x 1220 x 11 | 2440 | 1220 | 11 |
insert! | 2440 x 1220 x 15 | 2440 | 1220 | 15 |
insert! | 2440 x 1220 x 18 | 2440 | 1220 | 18 |
insert! | 2440 x 1200 x 30 | 2440 | 1200 | 30 |
custom! |
Plywood is a board material manufactured from thin layers or "plies" of wood veneer that are glued together with adjacent layers having their wood grain rotated up to 90 degrees to one another.
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
