Reload this page!
Home  > Boards  >
Plywood Boards - Imperial Units
Square edged plywood boards - Imperial Units
lumber
Nominal Dimension Length Width Thickness
in in in
insert! 8 x 4 x 1/4 95.93 47.5 0.250
insert! 8 x 4 x 3/8 95.93 47.5 0.344
insert! 8 x 4 x 1/2 95.93 47.5 0.469
insert! 8 x 4 x 5/8 95.93 47.5 0.593
insert! 8 x 4 x 3/4 95.93 47.5 0.719
insert! 8 x 4 x 1-1/8 95.93 47.5 1.125
custom!
Change before insert!
Plywood is a board material manufactured from thin layers or "plies" of wood veneer that are glued together with adjacent layers having their wood grain rotated up to 90 degrees to one another.
Tools - accessed from within Sketchup
Edit
undo!   redo!
Color
  change color!
View
iso!   top!   front!   right!   left!   back!   bottom!
Make Component
make!
Rotate Object(s)
around red!  , green!   or blue!   axis.
Move or Copy Object(s)
move/copy!
Knife
insert the Knife!   cut!
Move an Object to an other Objects Position
move!
Insert (Reference) Line
  startpoint
  endpoint         insert!
Insert Horizontal Plane
     insert!
Insert Vertical Plane
     insert!
     insert!
Insert Box
     insert!
