Sign in!
Home > Property - Land >
Metes and Bounds
Metes and bounds is a system or method of describing land,
metes and bound
The term "metes" refers to a boundary defined by the measurement of each straight run, specified by a distance between the terminal points, and an orientation or direction - a bearing. The term "bounds" refers to a more general boundary description, such as along a watercourse or an adjoining public road way.
In many deeds, the bearing is described not by a clockwise degree measure out of 360 degrees, but instead by indicating a direction north or south (N or S) followed by a degree measure out of 90 degrees and another direction west or east (W or E). For example, such a bearing might be listed as N 42o 35′ W, which means that the bearing is 42o35 counterclockwise (to the west) from north.
Delete, modify or add bearings and lengths in the table below. "Insert!" to add the area to your model.
Coordinates in Sketchup
Thickness
(ft)
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
