Sign in!
Home > Property - Land >
Latitude - Longitude Surface
Inserting a surface based on Latitude and Longitude coordinates
land property latitude longitude
Delete, modify or add Latitude and Longitude coordinates for the corners in area in the table below. "Insert!" to add the area to your model. Insertion point is row 0.
- latitude (0)
- longitude (0)
country
location
Set this position to
the models location!
Convert Degrees,
Minutes and Seconds
to Decimals!
thickness
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 21
