Sign in!
Home > Piping > Pipes and Tubes >
IS 4270 - Tubes
Pipes conforming to IS: 4270-2001 - metric units (mm)
tube
Nominal BoreOutside DiameterInside DiameterWall ThicknessMass
mmmmmmmmkg/m
insert!100114.3104.35.013.5
insert!125141.3131.35.016.8
insert!150168.3158.35.020.1
insert!175193.7182.95.425.1
insert!200219.1208.35.428.5
insert!225244.5232.56.035.3
insert!250273.1258.97.146.6
insert!300323.9309.77.155.5
custom!
mmmmmmmmkg/m
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
