Sign in!
Home > Property - Land >
Euref89
Inserting a surface based on EUREF89 coordinates - (European Reference Frame 1989)
euref89
Delete, modify or add X- and Y-coordinates for the corners in property in the table below. "Insert!" to add the property to your model. Insertion point is row 0.
thickness
Euref89 uses UTM (Universal Transversal Mercator) as projection - UTM[EUREF89] .
At the moment circel borders are not supported. Please use the Sketchup native circel and intersect tool after insertion.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 7
