ASME/ANSI B16.9 - 2001 Factory-Made Wrought Steel Buttwelding Fittings - Wall thickness : Standard, Extra Strong, Schedule 160 and Double Extra Strong
| Nominal Diameter | Strength | Outside Diameter | Radius Center | Wall Thickness | |
| in | in | in | in | ||
| insert! | 1/2 | STD | 0.840 | 1.5 | 0.109 |
| insert! | 3/4 | STD | 1.050 | 1.125 | 0.113 |
| insert! | 3/4 | XS | 1.050 | 1.125 | 0.154 |
| insert! | 1 | STD | 1.315 | 1.5 | 0.133 |
| insert! | 1 | XS | 1.315 | 1.5 | 0.179 |
| insert! | 1 | Sch 160 | 1.315 | 1.5 | 0.250 |
| insert! | 1 | XXS | 1.315 | 1.5 | 0.358 |
| insert! | 1 1/4 | STD | 1.660 | 1.875 | 0.140 |
| insert! | 1 1/4 | XS | 1.660 | 1.875 | 0.191 |
| insert! | 1 1/4 | Sch 160 | 1.660 | 1.875 | 0.250 |
| insert! | 1 1/4 | XXS | 1.660 | 1.875 | 0.382 |
| insert! | 1 1/2 | STD | 1.900 | 2.250 | 0.145 |
| insert! | 1 1/2 | XS | 1.900 | 2.250 | 0.200 |
| insert! | 1 1/2 | Sch 160 | 1.900 | 2.250 | 0.281 |
| insert! | 1 1/2 | XXS | 1.900 | 2.250 | 0.400 |
| insert! | 2 | STD | 2.375 | 3 | 0.154 |
| insert! | 2 | XS | 2.375 | 3 | 0.218 |
| insert! | 2 | Sch 160 | 2.375 | 3 | 0.343 |
| insert! | 2 | XXS | 2.375 | 3 | 0.436 |
| insert! | 2 1/2 | STD | 2.875 | 3.750 | 0.203 |
| insert! | 2 1/2 | XS | 2.875 | 3.750 | 0.276 |
| insert! | 2 1/2 | Sch 160 | 2.875 | 3.750 | 0.375 |
| insert! | 2 1/2 | XXS | 2.875 | 3.750 | 0.552 |
| insert! | 3 | STD | 3.500 | 4.5 | 0.216 |
| insert! | 3 | XS | 3.500 | 4.5 | 0.300 |
| insert! | 3 | Sch 160 | 3.500 | 4.5 | 0.438 |
| insert! | 3 | XXS | 3.500 | 4.5 | 0.600 |
| insert! | 3 1/2 | STD | 4.000 | 5.250 | 0.226 |
| insert! | 3 1/2 | XS | 4.000 | 5.250 | 0.318 |
| insert! | 3 1/2 | XXS | 4.000 | 5.250 | 0.636 |
| insert! | 4 | STD | 4.500 | 6 | 0.237 |
| insert! | 4 | XS | 4.500 | 6 | 0.337 |
| insert! | 4 | Sch 160 | 4.500 | 6 | 0.531 |
| insert! | 4 | XXS | 4.500 | 6 | 0.674 |
| insert! | 5 | STD | 5.563 | 7.5 | 0.258 |
| insert! | 5 | XS | 5.563 | 7.5 | 0.375 |
| insert! | 5 | Sch 160 | 5.563 | 7.5 | 0.625 |
| insert! | 5 | XXS | 5.563 | 7.5 | 0.750 |
| insert! | 6 | STD | 6.625 | 9 | 0.280 |
| insert! | 6 | XS | 6.625 | 9 | 0.432 |
| insert! | 6 | Sch 160 | 6.625 | 9 | 0.718 |
| insert! | 6 | XXS | 6.625 | 9 | 0.864 |
| insert! | 8 | STD | 8.625 | 12 | 0.322 |
| insert! | 8 | XS | 8.625 | 12 | 0.500 |
| insert! | 8 | Sch 160 | 8.625 | 12 | 0.906 |
| insert! | 8 | XXS | 8.625 | 12 | 0.875 |
| insert! | 10 | STD | 10.750 | 15 | 0.365 |
| insert! | 10 | XS | 10.750 | 15 | 0.500 |
| insert! | 10 | Sch 160 | 10.750 | 15 | 1.125 |
| insert! | 12 | STD | 12.750 | 18 | 0.375 |
| insert! | 12 | XS | 12.750 | 18 | 0.500 |
| insert! | 12 | Sch 160 | 12.750 | 18 | 1.312 |
| insert! | 14 | STD | 14.000 | 21 | 0.375 |
| insert! | 14 | XS | 14.000 | 21 | 0.500 |
| insert! | 14 | Sch 160 | 14.000 | 21 | 1.406 |
| insert! | 16 | STD | 16.000 | 24 | 0.375 |
| insert! | 16 | XS | 16.000 | 24 | 0.500 |
| insert! | 16 | Sch 160 | 16.000 | 24 | 1.593 |
| insert! | 18 | STD | 18.000 | 27 | 0.375 |
| insert! | 18 | XS | 18.000 | 27 | 0.500 |
| insert! | 22 | STD | 22.000 | 33 | 0.375 |
| insert! | 22 | XS | 22.000 | 33 | 0.500 |
| insert! | 24 | STD | 24.000 | 36 | 0.375 |
| insert! | 24 | XS | 24.000 | 36 | 0.500 |
| custom! | |||||
| in | in | in | in |
ASME/ANSI B16.9 - 2001 - Factory-Made Wrought Steel Buttwelding Fittings? - This Standard covers overall dimensions, tolerances, ratings, testing, and markings for wrought factory-made buttwelding fittings in sizes NPS 1/2 through 48 (DN 15 through 1200).
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
