Sign in!
Home > Piping > Elbows and Bends >
Butt Welded Short Radius 90 deg Elbows
ASME/ANSI B16.9 - 2001 - Factory-Made Wrought Steel Buttwelding Fittings - Wall thickness : Standard, Extra Strong, Schedule 160 and Double Extra Strong
piping elbow short radius 90
Nominal DiameterStrengthOutside DiameterRadius CenterWall Thickness
inininin
insert!1/2STD0.8400.50.109
insert!3/4STD1.0500.750.113
insert!3/4XS1.0500.750.154
insert!1STD1.31510.133
insert!1XS1.31510.179
insert!1Sch 1601.31510.250
insert!1XXS1.31510.358
insert!1 1/4STD1.6601.2500.140
insert!1 1/4XS1.6601.2500.191
insert!1 1/4Sch 1601.6601.2500.250
insert!1 1/4XXS1.6601.2500.382
insert!1 1/2STD1.9001.5000.145
insert!1 1/2XS1.9001.5000.200
insert!1 1/2Sch 1601.9001.5000.281
insert!1 1/2XXS1.9001.5000.400
insert!2STD2.37520.154
insert!2XS2.37520.218
insert!2Sch 1602.37520.343
insert!2XXS2.37520.436
insert!2 1/2STD2.8752.5000.203
insert!2 1/2XS2.8752.5000.276
insert!2 1/2Sch 1602.8752.5000.375
insert!2 1/2XXS2.8752.5000.552
insert!3STD3.50030.216
insert!3XS3.50030.300
insert!3Sch 1603.50030.438
insert!3XXS3.50030.600
insert!3 1/2STD4.0003.5000.226
insert!3 1/2XS4.0003.5000.318
insert!3 1/2XXS4.0003.5000.636
insert!4STD4.50040.237
insert!4XS4.50040.337
insert!4Sch 1604.50040.531
insert!4XXS4.50040.674
insert!5STD5.56350.258
insert!5XS5.56350.375
insert!5Sch 1605.56350.625
insert!5XXS5.56350.750
insert!6STD6.62560.280
insert!6XS6.62560.432
insert!6Sch 1606.62560.718
insert!6XXS6.62560.864
insert!8STD8.62580.322
insert!8XS8.62580.500
insert!8Sch 1608.62580.906
insert!8XXS8.62580.875
insert!10STD10.750100.365
insert!10XS10.750100.500
insert!10Sch 16010.750101.125
insert!12STD12.750120.375
insert!12XS12.750120.500
insert!12Sch 16012.750121.312
insert!14STD14.000140.375
insert!14XS14.000140.500
insert!14Sch 16014.000141.406
insert!16STD16.000160.375
insert!16XS16.000160.500
insert!16Sch 16016.000161.593
insert!18STD18.000180.375
insert!18XS18.000180.500
insert!22STD22.000220.375
insert!22XS22.000220.500
insert!24STD24.000240.375
insert!24XS24.000240.500
custom!
inininin
ASME/ANSI B16.9 - 2001 - Factory-Made Wrought Steel Buttwelding Fittings? - This Standard covers overall dimensions, tolerances, ratings, testing, and markings for wrought factory-made buttwelding fittings in sizes NPS 1/2 through 48 (DN 15 through 1200).
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
