HVAC Circular Spiral Ducts - imperial units
Add standard ducts to your Sketchup model by clicking "insert!
Customized ducts can be added by modifying the "custom!" row.
| Nominal Diameter | Outside Diameter | Wall Thickness | Weight | |
| in | in | in | lb/ft | |
| insert! | 3 | 3 | 0.0276 | 1.1 |
| insert! | 4 | 4 | 0.0276 | 1.4 |
| insert! | 5 | 5 | 0.0276 | 1.7 |
| insert! | 6 | 6 | 0.0276 | 2.0 |
| insert! | 7 | 7 | 0.0276 | 2.4 |
| insert! | 8 | 8 | 0.0276 | 2.8 |
| insert! | 9 | 9 | 0.0276 | 3.1 |
| insert! | 10 | 10 | 0.0276 | 3.4 |
| insert! | 11 | 11 | 0.0276 | 3.8 |
| insert! | 12 | 12 | 0.0276 | 4.1 |
| insert! | 13 | 13 | 0.0276 | 4.5 |
| insert! | 14 | 14 | 0.0276 | 4.8 |
| insert! | 15 | 15 | 0.0276 | 5.1 |
| insert! | 16 | 16 | 0.0276 | 5.5 |
| insert! | 17 | 17 | 0.0276 | 5.8 |
| insert! | 18 | 18 | 0.0276 | 6.1 |
| insert! | 20 | 20 | 0.0276 | 6.8 |
| insert! | 22 | 22 | 0.0336 | 9.1 |
| insert! | 24 | 24 | 0.0336 | 9.9 |
| insert! | 26 | 26 | 0.0336 | 10.8 |
| insert! | 28 | 28 | 0.0336 | 11.6 |
| insert! | 30 | 30 | 0.0336 | 12.4 |
| insert! | 32 | 32 | 0.0336 | 13.3 |
| insert! | 34 | 34 | 0.0336 | 14.1 |
| insert! | 36 | 36 | 0.0336 | 14.9 |
| insert! | 38 | 38 | 0.0396 | 18.5 |
| insert! | 40 | 40 | 0.0396 | 19.5 |
| insert! | 42 | 42 | 0.0396 | 20.5 |
| insert! | 44 | 44 | 0.0396 | 21.5 |
| insert! | 46 | 46 | 0.0396 | 22.5 |
| insert! | 48 | 48 | 0.0396 | 23.4 |
| insert! | 50 | 50 | 0.0516 | 32.4 |
| insert! | 52 | 52 | 0.0516 | 33.7 |
| insert! | 54 | 54 | 0.0516 | 35.0 |
| insert! | 56 | 56 | 0.0516 | 36.3 |
| insert! | 58 | 58 | 0.0516 | 37.6 |
| insert! | 60 | 60 | 0.0516 | 38.8 |
| insert! | 62 | 62 | 0.0516 | 41.1 |
| insert! | 64 | 64 | 0.0516 | 43.4 |
| insert! | 66 | 66 | 0.0516 | 44.7 |
| insert! | 68 | 68 | 0.0516 | 46.1 |
| insert! | 70 | 70 | 0.0516 | 47.4 |
| insert! | 72 | 72 | 0.0516 | 48.8 |
| custom! | ||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 20
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
