Home
Function Curves
Line made from the cubic equation
The Cubic Equation can be expressed as
y = ax 3 + bx 2 + cx + d
Add a cubic curve to your Sketchup model with the tool below!
Insert! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
