Sign in!
Home > Piping > Pipes and Tubes >
Copper Tubes - Type C
Dimensions and weights of copper tubes type C - metric units (mm)
copper tube type b
Nominal DiameterOutside DiameterInside DiameterWall ThicknessWeightInside Area
mmmmmmmmkg/mmm**2
insert!664.80.60.09118
insert!886.80.60.12536
insert!10108.80.60.15861
insert!121210.80.60.19292
insert!151513.60.70.281145
insert!181816.60.70.34216
insert!222220.40.80.476327
insert!282826.20.90.685539
insert!353532.81.11.05845
insert!424239.61.21.371231
insert!5454511.52.212042
insert!676763.81.62.943195
insert!797975.41.83.94463
insert!105105100.22.46.927881
insert!130130124.62.79.6512187
insert!156156149.83.113.317615
insert!206206197.44.324.430589
insert!257257246.25.438.247582
insert!308308295.26.454.268407
custom!
mmmmmmmmkg/mmm**2
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 22
