Sign in!
Home > Piping > Pipes and Tubes >
Copper Tubes - Type B
Dimensions and weights of copper tubes type B - metric units (mm)
copper tube type b
Nominal DiameterOutside DiameterInside DiameterWall ThicknessWeightInside Area
mmmmmmmmkg/mmm**2
insert!664.60.70.10417
insert!886.40.80.16232
insert!10108.40.80.20755
insert!121210.20.90.2882
insert!15151310.393133
insert!18181610.477201
insert!222219.81.10.646308
insert!282825.61.20.903514
insert!353532.21.41.32814
insert!4242391.51.711194
insert!545450.61.72.52010
insert!67676323.653116
insert!797974.42.34.954345
insert!10510599.42.88.047756
insert!130130123.83.11112031
insert!1561561493.51517428
insert!206206196528.230157
insert!257257244.46.344.446889
insert!308308293.87.16067760
custom!
mmmmmmmmkg/mmm**2
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 9 3
