Sign in!
Home > Piping > Pipes and Tubes >
Wrought Seamless Copper and Copper-Alloy Tubes
Standard Specification for General Requirements for Wrought Seamless Copper and Copper- Alloy Tube
copper alloy tube
Nominal DiameterAlternative IdentificationOutside DiameterInside DiameterWall ThicknessWeight
ininininlb/ft
insert!1/8STD0.4050.2810.0620.259
insert!1/8XS0.4050.2050.1000.371
insert!1/4STD0.5400.3760.0820.457
insert!1/4XS0.5400.2940.1230.625
insert!3/8STD0.6750.4950.090.641
insert!3/8XS0.6750.4210.1270.847
insert!1/2STD0.8400.6260.1070.955
insert!1/2XS0.8400.5420.1491.25
insert!3/4STD1.0500.8220.1141.30
insert!3/4XS1.0500.7360.1571.71
insert!1STD1.3151.0630.1261.82
insert!1XS1.3150.9510.1822.51
insert!1 1/4STD1.6601.3680.1462.69
insert!1 1/4XS1.6601.2720.1943.46
insert!1 1/2STD1.9001.6000.1503.20
insert!1 1/2XS1.9001.4940.2034.19
insert!2STD2.3752.0630.1564.22
insert!2XS2.3751.9330.2215.80
insert!2 1/2STD2.8752.5010.1876.12
insert!2 1/2XS2.8752.3150.2808.85
insert!3STD3.5003.0620.2198.75
insert!3XS3.5002.8920.30411.8
insert!3 1/2STD4.0003.5000.25011.4
insert!3 1/2XS4.0003.3580.32114.4
insert!4STD4.5004.0000.25012.9
insert!4XS4.5003.8180.34117.3
insert!5STD5.5635.0620.25116.2
insert!5XS5.5634.8120.37623.7
insert!6STD6.6256.1250.25019.4
insert!6XS6.6255.7510.43732.9
insert!8STD8.6258.0010.31231.6
insert!8XS8.6257.6250.50049.5
insert!10STD10.75010.0200.36546.2
insert!10XS10.7509.7500.50062.4
insert!12STD12.75012.0000.37556.5
custom!
ininininlb/ft
?Tip! Adjust pipe length after insert by selecting the pipe and using the Scale or the Push/Pull tool.?
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
