Dimensions of circular hollow steel sections - metric units (mm)
| Nominal Diameter | Outside Diameter | Inside Diameter | Wall Thickness | |
| mm | mm | mm | mm | |
| insert! | 20 | 20 | 18.0 | 1.0 |
| insert! | 20 | 20 | 17.6 | 1.2 |
| insert! | 20 | 20 | 17.0 | 1.5 |
| insert! | 20 | 20 | 16.0 | 2.0 |
| insert! | 20 | 20 | 15.0 | 2.5 |
| insert! | 25 | 25 | 23.0 | 1.0 |
| insert! | 25 | 25 | 22.6 | 1.2 |
| insert! | 25 | 25 | 22.0 | 1.5 |
| insert! | 25 | 25 | 21.0 | 2.0 |
| insert! | 25 | 25 | 20.0 | 2.5 |
| insert! | 30 | 30 | 27.6 | 1.2 |
| insert! | 30 | 30 | 27.0 | 1.5 |
| insert! | 30 | 30 | 26.0 | 2.0 |
| insert! | 30 | 30 | 25.0 | 2.5 |
| insert! | 30 | 30 | 24.0 | 3.0 |
| insert! | 33 | 33 | 30.6 | 1.2 |
| insert! | 33 | 33 | 30.0 | 1.5 |
| insert! | 33 | 33 | 29.0 | 2.0 |
| insert! | 33 | 33 | 28.0 | 2.5 |
| insert! | 33 | 33 | 27.0 | 3.0 |
| insert! | 38 | 38 | 35.6 | 1.2 |
| insert! | 38 | 38 | 35.0 | 1.5 |
| insert! | 38 | 38 | 34.0 | 2.0 |
| insert! | 38 | 38 | 33.0 | 2.5 |
| insert! | 38 | 38 | 32.0 | 3.0 |
| insert! | 41 | 41 | 38.6 | 1.2 |
| insert! | 41 | 41 | 38.0 | 1.5 |
| insert! | 41 | 41 | 37.0 | 2.0 |
| insert! | 41 | 41 | 36.0 | 2.5 |
| insert! | 41 | 41 | 35.0 | 3.0 |
| insert! | 47 | 47 | 44.6 | 1.2 |
| insert! | 47 | 47 | 44.0 | 1.5 |
| insert! | 47 | 47 | 43.0 | 2.0 |
| insert! | 47 | 47 | 42.0 | 2.5 |
| insert! | 47 | 47 | 41.0 | 3.0 |
| insert! | 50 | 50 | 47.0 | 1.5 |
| insert! | 50 | 50 | 46.0 | 2.0 |
| insert! | 50 | 50 | 45.0 | 2.5 |
| insert! | 50 | 50 | 44.0 | 3.0 |
| insert! | 50 | 50 | 43.6 | 3.2 |
| insert! | 57 | 57 | 54.0 | 1.5 |
| insert! | 57 | 57 | 53.0 | 2.0 |
| insert! | 57 | 57 | 52.0 | 2.5 |
| insert! | 57 | 57 | 51.0 | 3.0 |
| insert! | 57 | 57 | 50.6 | 3.2 |
| insert! | 63 | 63 | 60.0 | 1.5 |
| insert! | 63 | 63 | 59.0 | 2.0 |
| insert! | 63 | 63 | 58.0 | 2.5 |
| insert! | 63 | 63 | 57.0 | 3.0 |
| insert! | 63 | 63 | 56.6 | 3.2 |
| insert! | 75 | 75 | 72.0 | 1.5 |
| insert! | 75 | 75 | 71.0 | 2.0 |
| insert! | 75 | 75 | 70.0 | 2.5 |
| insert! | 75 | 75 | 69.0 | 3.0 |
| insert! | 75 | 75 | 68.6 | 3.2 |
| insert! | 88 | 88 | 85.0 | 1.5 |
| insert! | 88 | 88 | 84.0 | 2.0 |
| insert! | 88 | 88 | 83.0 | 2.5 |
| insert! | 88 | 88 | 82.0 | 3.0 |
| insert! | 88 | 88 | 81.6 | 3.2 |
| custom! | ||||
| mm | mm | mm | mm |
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
