Reducing outlet butt welded tees according ASME B.16.9 - outside dimensions valid for all schedules
| Nominal Diameter | Run Diameter | Run | Run Thickness | Outlet Diameter | Outlet | Outlet Thickness | |
| in | in | in | in | in | in | in | |
| insert! | 1/2 x 1/2 x 1/4 | 0.840 | 1.00 | 0.109 | 0.680 | 1.00 | 0.109 |
| insert! | 1/2 x 1/2 x 3/8 | 0.840 | 1.00 | 0.109 | 0.54 | 1.00 | 0.109 |
| insert! | 3/4 x 3/4 x 3/8 | 1.050 | 1.12 | 0.113 | 0.84 | 1.12 | 0.109 |
| insert! | 3/4 x 3/4 x 1/2 | 1.010 | 1.12 | 0.113 | 0.68 | 1.12 | 0.109 |
| insert! | 1 x 1 x 3/4 | 1.315 | 1.50 | 0.133 | 1.05 | 1.50 | 0.113 |
| insert! | 1 x 1 x 1/2 | 1.315 | 1.50 | 0.133 | 0.84 | 1.50 | 0.109 |
| insert! | 1 1/4 x 1 1/4 x 1 | 1.66 | 1.88 | 0.140 | 1.32 | 1.88 | 0.133 |
| insert! | 1 1/4 x 1 1/4 x 3/4 | 1.66 | 1.88 | 0.140 | 1.05 | 1.88 | 0.113 |
| insert! | 1 1/4 x 1 1/4 x 1/2 | 1.66 | 1.88 | 0.140 | 0.84 | 1.88 | 0.109 |
| insert! | 1 1/2 x 1 1/2 x 1 1/4 | 1.90 | 2.25 | 0.145 | 1.66 | 2.25 | 0.140 |
| insert! | 1 1/2 x 1 1/2 x 1 | 1.90 | 2.25 | 0.145 | 1.32 | 2.25 | 0.133 |
| insert! | 1 1/2 x 1 1/2 x 3/4 | 1.90 | 2.25 | 0.145 | 1.05 | 2.25 | 0.113 |
| insert! | 1 1/2 x 1 1/2 x 1/2 | 1.90 | 2.25 | 0.145 | 0.84 | 2.25 | 0.109 |
| insert! | 2 x 2 x 1 1/2 | 2.375 | 2.50 | 0.154 | 1.90 | 2.38 | 0.145 |
| insert! | 2 x 2 x 1 1/4 | 2.375 | 2.50 | 0.154 | 1.66 | 2.25 | 0.140 |
| insert! | 2 x 2 x 1 | 2.375 | 2.50 | 0.154 | 1.32 | 2.00 | 0.133 |
| insert! | 2 x 2 x 3/4 | 2.375 | 2.50 | 0.154 | 1.05 | 1.75 | 0.113 |
| insert! | 2 1/2 x 2 1/2 x 2 | 2.875 | 3.00 | 0.203 | 2.38 | 2.75 | 0.154 |
| insert! | 2 1/2 x 2 1/2 x 1 1/2 | 2.875 | 3.00 | 0.203 | 1.90 | 2.62 | 0.145 |
| insert! | 2 1/2 x 2 1/2 x 1 1/4 | 2.875 | 3.00 | 0.203 | 1.66 | 2.50 | 0.140 |
| insert! | 2 1/2 x 2 1/2 x 1 | 2.875 | 3.00 | 0.203 | 1.32 | 2.25 | 0.133 |
| insert! | 3 x 3 x 2 1/2 | 3.50 | 3.38 | 0.216 | 2.88 | 3.25 | 0.203 |
| insert! | 3 x 3 x 2 | 3.50 | 3.38 | 0.216 | 2.38 | 3.00 | 0.154 |
| insert! | 3 x 3 x 1 1/2 | 3.50 | 3.38 | 0.216 | 1.90 | 2.88 | 0.145 |
| insert! | 3 x 3 x 1 1/4 | 3.50 | 3.38 | 0.216 | 1.66 | 2.75 | 0.140 |
| insert! | 3 1/2 x 3 1/2 x 3 | 4.00 | 3.75 | 0.226 | 3.50 | 3.62 | 0.216 |
| insert! | 3 1/2 x 3 1/2 x 2 1/2 | 4.00 | 3.75 | 0.226 | 2.88 | 3.50 | 0.203 |
| insert! | 3 1/2 x 3 1/2 x 2 | 4.00 | 3.75 | 0.226 | 2.38 | 3.25 | 0.154 |
| insert! | 3 1/2 x 3 1/2 x 1 1/2 | 4.00 | 3.75 | 0.226 | 1.90 | 3.12 | 0.145 |
| insert! | 4 x 4 x 3 1/2 | 4.50 | 4.12 | 0.237 | 4.00 | 4.00 | 0.226 |
| insert! | 4 x 4 x 3 | 4.50 | 4.12 | 0.237 | 3.50 | 3.88 | 0.216 |
| insert! | 4 x 4 x 2 1/2 | 4.50 | 4.12 | 0.237 | 2.88 | 3.75 | 0.203 |
| insert! | 4 x 4 x 2 | 4.50 | 4.12 | 0.237 | 2.38 | 3.50 | 0.154 |
| insert! | 4 x 4 x 1 1/2 | 4.50 | 4.12 | 0.237 | 1.90 | 3.38 | 0.145 |
| insert! | 5 x 5 x 4 | 5.563 | 4.88 | 0.258 | 4.50 | 4.62 | 0.237 |
| insert! | 5 x 5 x 3 1/2 | 5.563 | 4.88 | 0.258 | 4.00 | 4.50 | 0.226 |
| insert! | 5 x 5 x 3 | 5.563 | 4.88 | 0.258 | 3.50 | 4.38 | 0.216 |
| insert! | 5 x 5 x 2 1/2 | 5.563 | 4.88 | 0.258 | 2.88 | 4.25 | 0.203 |
| insert! | 5 x 5 x 2 | 5.563 | 4.88 | 0.258 | 2.38 | 4.12 | 0.154 |
| insert! | 6 x 6 x 5 | 6.625 | 5.62 | 0.280 | 5.56 | 5.38 | 0.258 |
| insert! | 6 x 6 x 4 | 6.625 | 5.62 | 0.280 | 4.50 | 5.12 | 0.237 |
| insert! | 6 x 6 x 3 1/2 | 6.625 | 5.62 | 0.280 | 4.00 | 5.00 | 0.226 |
| insert! | 6 x 6 x 3 | 6.625 | 5.62 | 0.280 | 3.50 | 4.88 | 0.216 |
| insert! | 6 x 6 x 2 1/2 | 6.625 | 5.62 | 0.280 | 2.88 | 4.75 | 0.203 |
| insert! | 8 x 8 x 6 | 8.625 | 7.00 | 0.322 | 6.62 | 6.62 | 0.280 |
| insert! | 8 x 8 x 5 | 8.625 | 7.00 | 0.322 | 5.56 | 6.38 | 0.258 |
| insert! | 8 x 8 x 4 | 8.625 | 7.00 | 0.322 | 4.50 | 6.12 | 0.237 |
| insert! | 8 x 8 x 3 1/2 | 8.625 | 7.00 | 0.322 | 4.00 | 6.00 | 0.226 |
| insert! | 10 x 10 x 8 | 10.75 | 8.50 | 0.365 | 8.62 | 8.00 | 0.322 |
| insert! | 10 x 10 x 6 | 10.75 | 8.50 | 0.365 | 6.62 | 7.62 | 0.280 |
| insert! | 10 x 10 x 5 | 10.75 | 8.50 | 0.365 | 5.56 | 7.50 | 0.258 |
| insert! | 10 x 10 x 4 | 10.75 | 8.50 | 0.365 | 4.50 | 7.25 | 0.237 |
| insert! | 12 x 12 x 10 | 12.75 | 10.00 | 0.375 | 10.75 | 9.50 | 0.365 |
| insert! | 12 x 12 x 8 | 12.75 | 10.00 | 0.375 | 8.62 | 9.00 | 0.322 |
| insert! | 12 x 12 x 6 | 12.75 | 10.00 | 0.375 | 6.62 | 8.62 | 0.280 |
| insert! | 12 x 12 x 5 | 12.75 | 10.00 | 0.375 | 5.56 | 8.50 | 0.258 |
| insert! | 14 x 14 x 12 | 14.00 | 11.00 | 0.375 | 12.75 | 10.62 | 0.375 |
| insert! | 14 x 14 x 10 | 14.00 | 11.00 | 0.375 | 10.75 | 10.12 | 0.365 |
| insert! | 14 x 14 x 8 | 14.00 | 11.00 | 0.375 | 8.62 | 9.75 | 0.322 |
| insert! | 14 x 14 x 6 | 14.00 | 11.00 | 0.375 | 6.62 | 9.38 | 0.280 |
| insert! | 16 x 16 x 14 | 16.00 | 12.00 | 0.375 | 14.00 | 12.00 | 0.375 |
| insert! | 16 x 16 x 12 | 16.00 | 12.00 | 0.375 | 12.75 | 11.62 | 0.375 |
| insert! | 16 x 16 x 10 | 16.00 | 12.00 | 0.375 | 10.75 | 11.12 | 0.365 |
| insert! | 16 x 16 x 8 | 16.00 | 12.00 | 0.375 | 8.62 | 10.75 | 0.322 |
| insert! | 16 x 16 x 6 | 16.00 | 12.00 | 0.375 | 6.62 | 10.38 | 0.280 |
| insert! | 18 x 18 x 16 | 18.00 | 13.50 | 0.375 | 16.00 | 13.00 | 0.375 |
| insert! | 18 x 18 x 14 | 18.00 | 13.50 | 0.375 | 14.00 | 13.00 | 0.375 |
| insert! | 18 x 18 x 12 | 18.00 | 13.50 | 0.375 | 12.75 | 12.62 | 0.375 |
| insert! | 18 x 18 x 10 | 18.00 | 13.50 | 0.375 | 10.75 | 12.12 | 0.365 |
| insert! | 18 x 18 x 8 | 18.00 | 13.50 | 0.375 | 8.62 | 11.75 | 0.322 |
| insert! | 20 x 20 x 18 | 20.00 | 15.00 | 0.375 | 18.00 | 14.50 | 0.375 |
| insert! | 20 x 20 x 16 | 20.00 | 15.00 | 0.375 | 16.00 | 14.00 | 0.375 |
| insert! | 20 x 20 x 14 | 20.00 | 15.00 | 0.375 | 14.00 | 14.00 | 0.375 |
| insert! | 20 x 20 x 12 | 20.00 | 15.00 | 0.375 | 12.75 | 13.62 | 0.375 |
| insert! | 20 x 20 x 10 | 20.00 | 15.00 | 0.375 | 10.75 | 13.12 | 0.365 |
| insert! | 20 x 20 x 8 | 20.00 | 15.00 | 0.375 | 8.62 | 12.75 | 0.322 |
| insert! | 22 x 22 x 20 | 22.00 | 16.50 | 0.375 | 20.00 | 16.00 | 0.375 |
| insert! | 22 x 22 x 18 | 22.00 | 16.50 | 0.375 | 18.00 | 15.50 | 0.375 |
| insert! | 22 x 22 x 16 | 22.00 | 16.50 | 0.375 | 16.00 | 15.00 | 0.375 |
| insert! | 22 x 22 x 14 | 22.00 | 16.50 | 0.375 | 14.00 | 15.00 | 0.375 |
| insert! | 22 x 22 x 12 | 22.00 | 16.50 | 0.375 | 12.75 | 14.625 | 0.375 |
| insert! | 22 x 22 x 10 | 22.00 | 16.50 | 0.375 | 10.75 | 14.125 | 0.365 |
| insert! | 24 x 24 x 22 | 24.00 | 17.00 | 0.375 | 22.00 | 17.00 | 0.375 |
| insert! | 24 x 24 x 20 | 24.00 | 17.00 | 0.375 | 20.00 | 17.00 | 0.375 |
| insert! | 24 x 24 x 18 | 24.00 | 17.00 | 0.375 | 18.00 | 16.50 | 0.375 |
| insert! | 24 x 24 x 16 | 24.00 | 17.00 | 0.375 | 16.00 | 16.00 | 0.375 |
| insert! | 24 x 24 x 14 | 24.00 | 17.00 | 0.375 | 14.00 | 16.00 | 0.375 |
| insert! | 24 x 24 x 12 | 24.00 | 17.00 | 0.375 | 12.75 | 15.625 | 0.375 |
| insert! | 24 x 24 x 10 | 24.00 | 17.00 | 0.375 | 10.75 | 15.125 | 0.365 |
| insert! | 26 x 26 x 24 | 26.00 | 19.50 | 0.375 | 24.00 | 19.00 | 0.375 |
| insert! | 26 x 26 x 22 | 26.00 | 19.50 | 0.375 | 22.00 | 18.50 | 0.375 |
| insert! | 26 x 26 x 20 | 26.00 | 19.50 | 0.375 | 20.00 | 18.00 | 0.375 |
| insert! | 26 x 26 x 18 | 26.00 | 19.50 | 0.375 | 18.00 | 17.50 | 0.375 |
| insert! | 26 x 26 x 16 | 26.00 | 19.50 | 0.375 | 16.00 | 17.00 | 0.375 |
| insert! | 26 x 26 x 14 | 26.00 | 19.50 | 0.375 | 14.00 | 17.00 | 0.375 |
| insert! | 26 x 26 x 12 | 26.00 | 19.50 | 0.375 | 12.75 | 16.625 | 0.375 |
| insert! | 28 x 28 x 26 | 28.00 | 20.50 | 0.375 | 26.00 | 20.50 | 0.375 |
| insert! | 28 x 28 x 24 | 28.00 | 20.50 | 0.375 | 24.00 | 20.00 | 0.375 |
| insert! | 28 x 28 x 22 | 28.00 | 20.50 | 0.375 | 22.00 | 19.50 | 0.375 |
| insert! | 28 x 28 x 20 | 28.00 | 20.50 | 0.375 | 20.00 | 19.00 | 0.375 |
| insert! | 28 x 28 x 18 | 28.00 | 20.50 | 0.375 | 18.00 | 18.50 | 0.375 |
| insert! | 28 x 28 x 16 | 28.00 | 20.50 | 0.375 | 16.00 | 18.00 | 0.375 |
| insert! | 28 x 28 x 14 | 28.00 | 20.50 | 0.375 | 14.00 | 18.00 | 0.375 |
| insert! | 28 x 28 x 12 | 28.00 | 20.50 | 0.375 | 12.75 | 17.625 | 0.375 |
| insert! | 30 x 30 x 28 | 30.00 | 22.00 | 0.375 | 28.00 | 21.50 | 0.375 |
| insert! | 30 x 30 x 26 | 30.00 | 22.00 | 0.375 | 26.00 | 21.50 | 0.375 |
| insert! | 30 x 30 x 24 | 30.00 | 22.00 | 0.375 | 24.00 | 21.00 | 0.375 |
| insert! | 30 x 30 x 22 | 30.00 | 22.00 | 0.375 | 22.00 | 20.50 | 0.375 |
| insert! | 30 x 30 x 20 | 30.00 | 22.00 | 0.375 | 20.00 | 20.00 | 0.375 |
| insert! | 30 x 30 x 18 | 30.00 | 22.00 | 0.375 | 18.00 | 19.50 | 0.375 |
| insert! | 30 x 30 x 16 | 30.00 | 22.00 | 0.375 | 16.00 | 19.00 | 0.375 |
| insert! | 30 x 30 x 14 | 30.00 | 22.00 | 0.375 | 14.00 | 19.00 | 0.375 |
| insert! | 30 x 30 x 12 | 30.00 | 22.00 | 0.375 | 12.75 | 18.625 | 0.375 |
| insert! | 30 x 30 x 10 | 30.00 | 22.00 | 0.375 | 10.75 | 18.125 | 0.375 |
| insert! | 32 x 32 x 30 | 32.00 | 23.50 | 0.375 | 30.00 | 23.00 | 0.375 |
| insert! | 32 x 32 x 28 | 32.00 | 23.50 | 0.375 | 28.00 | 22.50 | 0.375 |
| insert! | 32 x 32 x 26 | 32.00 | 23.50 | 0.375 | 26.00 | 22.50 | 0.375 |
| insert! | 32 x 32 x 24 | 32.00 | 23.50 | 0.375 | 24.00 | 22.00 | 0.375 |
| insert! | 32 x 32 x 22 | 32.00 | 23.50 | 0.375 | 22.00 | 21.50 | 0.375 |
| insert! | 32 x 32 x 20 | 32.00 | 23.50 | 0.375 | 20.00 | 21.00 | 0.375 |
| insert! | 32 x 32 x 18 | 32.00 | 23.50 | 0.375 | 18.00 | 20.50 | 0.375 |
| insert! | 32 x 32 x 16 | 32.00 | 23.50 | 0.375 | 16.00 | 20.00 | 0.375 |
| insert! | 32 x 32 x 14 | 32.00 | 23.50 | 0.375 | 14.00 | 20.00 | 0.375 |
| insert! | 34 x 34 x 32 | 34.00 | 25.00 | 0.375 | 32.00 | 24.50 | 0.375 |
| insert! | 34 x 34 x 30 | 34.00 | 25.00 | 0.375 | 30.00 | 24.00 | 0.375 |
| insert! | 34 x 34 x 28 | 34.00 | 25.00 | 0.375 | 28.00 | 23.50 | 0.375 |
| insert! | 34 x 34 x 26 | 34.00 | 25.00 | 0.375 | 26.00 | 23.50 | 0.375 |
| insert! | 34 x 34 x 24 | 34.00 | 25.00 | 0.375 | 24.00 | 23.00 | 0.375 |
| insert! | 34 x 34 x 22 | 34.00 | 25.00 | 0.375 | 22.00 | 22.50 | 0.375 |
| insert! | 34 x 34 x 20 | 34.00 | 25.00 | 0.375 | 20.00 | 22.00 | 0.375 |
| insert! | 34 x 34 x 18 | 34.00 | 25.00 | 0.375 | 18.00 | 21.50 | 0.375 |
| insert! | 34 x 34 x 16 | 34.00 | 25.00 | 0.375 | 16.00 | 21.00 | 0.375 |
| insert! | 36 x 36 x 34 | 36.00 | 26.50 | 0.375 | 34.00 | 26.00 | 0.375 |
| insert! | 36 x 36 x 32 | 36.00 | 26.50 | 0.375 | 32.00 | 25.50 | 0.375 |
| insert! | 36 x 36 x 30 | 36.00 | 26.50 | 0.375 | 30.00 | 25.00 | 0.375 |
| insert! | 36 x 36 x 28 | 36.00 | 26.50 | 0.375 | 28.00 | 24.50 | 0.375 |
| insert! | 36 x 36 x 26 | 36.00 | 26.50 | 0.375 | 26.00 | 24.50 | 0.375 |
| insert! | 36 x 36 x 24 | 36.00 | 26.50 | 0.375 | 24.00 | 24.00 | 0.375 |
| insert! | 36 x 36 x 22 | 36.00 | 26.50 | 0.375 | 22.00 | 23.50 | 0.375 |
| insert! | 36 x 36 x 20 | 36.00 | 26.50 | 0.375 | 20.00 | 23.50 | 0.375 |
| insert! | 36 x 36 x 18 | 36.00 | 26.50 | 0.375 | 18.00 | 22.50 | 0.375 |
| insert! | 36 x 36 x 16 | 36.00 | 26.50 | 0.375 | 16.00 | 22.00 | 0.375 |
| insert! | 38 x 38 x 36 | 38.00 | 28.00 | 0.375 | 36.00 | 28.00 | 0.375 |
| insert! | 38 x 38 x 34 | 38.00 | 28.00 | 0.375 | 34.00 | 27.50 | 0.375 |
| insert! | 38 x 38 x 32 | 38.00 | 28.00 | 0.375 | 32.00 | 27.00 | 0.375 |
| insert! | 38 x 38 x 30 | 38.00 | 28.00 | 0.375 | 30.00 | 26.50 | 0.375 |
| insert! | 38 x 38 x 28 | 38.00 | 28.00 | 0.375 | 28.00 | 25.50 | 0.375 |
| insert! | 38 x 38 x 26 | 38.00 | 28.00 | 0.375 | 26.00 | 25.50 | 0.375 |
| insert! | 38 x 38 x 24 | 38.00 | 28.00 | 0.375 | 24.00 | 25.00 | 0.375 |
| insert! | 38 x 38 x 22 | 38.00 | 28.00 | 0.375 | 22.00 | 24.50 | 0.375 |
| insert! | 38 x 38 x 20 | 38.00 | 28.00 | 0.375 | 20.00 | 24.00 | 0.375 |
| insert! | 38 x 38 x 18 | 38.00 | 28.00 | 0.375 | 18.00 | 23.50 | 0.375 |
| insert! | 40 x 40 x 38 | 40.00 | 29.50 | 0.375 | 38.00 | 29.50 | 0.375 |
| insert! | 40 x 40 x 36 | 40.00 | 29.50 | 0.375 | 36.00 | 29.00 | 0.375 |
| insert! | 40 x 40 x 34 | 40.00 | 29.50 | 0.375 | 34.00 | 28.50 | 0.375 |
| insert! | 40 x 40 x 32 | 40.00 | 29.50 | 0.375 | 32.00 | 28.00 | 0.375 |
| insert! | 40 x 40 x 30 | 40.00 | 29.50 | 0.375 | 30.00 | 27.50 | 0.375 |
| insert! | 40 x 40 x 28 | 40.00 | 29.50 | 0.375 | 28.00 | 26.50 | 0.375 |
| insert! | 40 x 40 x 26 | 40.00 | 29.50 | 0.375 | 26.00 | 26.50 | 0.375 |
| insert! | 40 x 40 x 24 | 40.00 | 29.50 | 0.375 | 24.00 | 26.00 | 0.375 |
| insert! | 40 x 40 x 22 | 40.00 | 29.50 | 0.375 | 22.00 | 25.50 | 0.375 |
| insert! | 40 x 40 x 20 | 40.00 | 29.50 | 0.375 | 20.00 | 25.00 | 0.375 |
| insert! | 40 x 40 x 18 | 40.00 | 29.50 | 0.375 | 18.00 | 24.50 | 0.375 |
| insert! | 42 x 42 x 40 | 42.00 | 30.00 | 0.375 | 40.00 | 28.00 | 0.375 |
| insert! | 42 x 42 x 38 | 42.00 | 30.00 | 0.375 | 38.00 | 28.00 | 0.375 |
| insert! | 42 x 42 x 36 | 42.00 | 30.00 | 0.375 | 36.00 | 28.00 | 0.375 |
| insert! | 42 x 42 x 34 | 42.00 | 30.00 | 0.375 | 34.00 | 28.00 | 0.375 |
| insert! | 42 x 42 x 32 | 42.00 | 30.00 | 0.375 | 32.00 | 28.00 | 0.375 |
| insert! | 42 x 42 x 30 | 42.00 | 30.00 | 0.375 | 30.00 | 28.00 | 0.375 |
| insert! | 42 x 42 x 28 | 42.00 | 30.00 | 0.375 | 28.00 | 27.50 | 0.375 |
| insert! | 42 x 42 x 26 | 42.00 | 30.00 | 0.375 | 26.00 | 27.50 | 0.375 |
| insert! | 42 x 42 x 24 | 42.00 | 30.00 | 0.375 | 24.00 | 26.00 | 0.375 |
| insert! | 42 x 42 x 22 | 42.00 | 30.00 | 0.375 | 22.00 | 26.00 | 0.375 |
| insert! | 42 x 42 x 20 | 42.00 | 30.00 | 0.375 | 20.00 | 26.00 | 0.375 |
| insert! | 42 x 42 x 18 | 42.00 | 30.00 | 0.375 | 18.00 | 25.50 | 0.375 |
| insert! | 42 x 42 x 16 | 42.00 | 30.00 | 0.375 | 16.00 | 25.00 | 0.375 |
| insert! | 44 x 44 x 42 | 44.00 | 32.00 | 0.375 | 42.00 | 30.00 | 0.375 |
| insert! | 44 x 44 x 40 | 44.00 | 32.00 | 0.375 | 40.00 | 29.50 | 0.375 |
| insert! | 44 x 44 x 38 | 44.00 | 32.00 | 0.375 | 38.00 | 29.00 | 0.375 |
| insert! | 44 x 44 x 36 | 44.00 | 32.00 | 0.375 | 36.00 | 28.50 | 0.375 |
| insert! | 44 x 44 x 34 | 44.00 | 32.00 | 0.375 | 34.00 | 28.50 | 0.375 |
| insert! | 44 x 44 x 32 | 44.00 | 32.00 | 0.375 | 32.00 | 28.00 | 0.375 |
| insert! | 44 x 44 x 30 | 44.00 | 32.00 | 0.375 | 30.00 | 28.00 | 0.375 |
| insert! | 44 x 44 x 28 | 44.00 | 32.00 | 0.375 | 28.00 | 27.50 | 0.375 |
| insert! | 44 x 44 x 26 | 44.00 | 32.00 | 0.375 | 26.00 | 27.50 | 0.375 |
| insert! | 44 x 44 x 24 | 44.00 | 32.00 | 0.375 | 24.00 | 27.50 | 0.375 |
| insert! | 44 x 44 x 22 | 44.00 | 32.00 | 0.375 | 22.00 | 27.00 | 0.375 |
| insert! | 44 x 44 x 20 | 44.00 | 32.00 | 0.375 | 20.00 | 27.00 | 0.375 |
| insert! | 46 x 46 x 44 | 46.00 | 33.50 | 0.375 | 44.00 | 31.50 | 0.375 |
| insert! | 46 x 46 x 42 | 46.00 | 33.50 | 0.375 | 42.00 | 31.00 | 0.375 |
| insert! | 46 x 46 x 40 | 46.00 | 33.50 | 0.375 | 40.00 | 30.50 | 0.375 |
| insert! | 46 x 46 x 38 | 46.00 | 33.50 | 0.375 | 38.00 | 30.00 | 0.375 |
| insert! | 46 x 46 x 36 | 46.00 | 33.50 | 0.375 | 36.00 | 30.00 | 0.375 |
| insert! | 46 x 46 x 34 | 46.00 | 33.50 | 0.375 | 34.00 | 29.50 | 0.375 |
| insert! | 46 x 46 x 32 | 46.00 | 33.50 | 0.375 | 32.00 | 29.50 | 0.375 |
| insert! | 46 x 46 x 30 | 46.00 | 33.50 | 0.375 | 30.00 | 29.00 | 0.375 |
| insert! | 46 x 46 x 28 | 46.00 | 33.50 | 0.375 | 28.00 | 29.00 | 0.375 |
| insert! | 46 x 46 x 26 | 46.00 | 33.50 | 0.375 | 26.00 | 29.00 | 0.375 |
| insert! | 46 x 46 x 24 | 46.00 | 33.50 | 0.375 | 24.00 | 28.50 | 0.375 |
| insert! | 46 x 46 x 22 | 46.00 | 33.50 | 0.375 | 22.00 | 28.50 | 0.375 |
| insert! | 48 x 48 x 46 | 48.00 | 35.00 | 0.375 | 46.00 | 33.00 | 0.375 |
| insert! | 48 x 48 x 44 | 48.00 | 35.00 | 0.375 | 44.00 | 33.00 | 0.375 |
| insert! | 48 x 48 x 42 | 48.00 | 35.00 | 0.375 | 42.00 | 32.00 | 0.375 |
| insert! | 48 x 48 x 40 | 48.00 | 35.00 | 0.375 | 40.00 | 32.00 | 0.375 |
| insert! | 48 x 48 x 38 | 48.00 | 35.00 | 0.375 | 38.00 | 32.00 | 0.375 |
| insert! | 48 x 48 x 36 | 48.00 | 35.00 | 0.375 | 36.00 | 31.00 | 0.375 |
| insert! | 48 x 48 x 34 | 48.00 | 35.00 | 0.375 | 34.00 | 31.00 | 0.375 |
| insert! | 48 x 48 x 32 | 48.00 | 35.00 | 0.375 | 32.00 | 31.00 | 0.375 |
| insert! | 48 x 48 x 30 | 48.00 | 35.00 | 0.375 | 30.00 | 30.00 | 0.375 |
| insert! | 48 x 48 x 28 | 48.00 | 35.00 | 0.375 | 28.00 | 30.00 | 0.375 |
| insert! | 48 x 48 x 26 | 48.00 | 35.00 | 0.375 | 26.00 | 30.00 | 0.375 |
| insert! | 48 x 48 x 24 | 48.00 | 35.00 | 0.375 | 24.00 | 29.00 | 0.375 |
| insert! | 48 x 48 x 22 | 48.00 | 35.00 | 0.375 | 22.00 | 29.00 | 0.375 |
| custom! | |||||||
Note! Outside diameters and dimensions are correct for all schedules.
Thickness are based on standard schedules. Use custom insert at the end of the table to insert custom components with other schedules.
If internal details are important for your application - modify the component after inserted by selecting the internal faces,
right clicking, and using the Intersecting tool - remove all unwanted faces and lines.
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 8
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
